First post, by Doppler
Is it possible to disable or hide A: and B: drive letters in MS-DOS so that they couldnt be accessed and seen in file managers like norton/volkov commander?
I know it's just a visual preference, but still I dont use any diskette drives in my computer so I would be happy to disable these letters 😀
Reply 2 of 6, by derSammler
Unless a program is badly coded, you should not see A: and/or B: when setting them to "none" in the BIOS.
Reply 3 of 6, by Doppler
Kamerat wrote:
You can use Drive Letter Manipulator for that purpose.
Thanks! it works! 😁
Reply 4 of 6, by Cyberdyne
Sometimes, even DOS is badly coded, and even BIOS is badly coded, and those A and B drive are hard to die form your list.
Reply 6 of 6, by Doppler
Reporting back with more tests.
Unfortunately it works only under volkov commander. In Dos Navigator and others similar file managers, the A letter is still visible, no matter what. Look like I'll have to live with it 😀 But anyway, thanks one more time!
