First post, by keenerb
keenerb
Offline
I'm using Sergey's floppy bios with an HD floppy controller, modified to disable the on-board Tandy floppy controller.
If I use this bios with no boot floppy in the drive, I'll ultimately get an error about no system disk/boot failure.
I'd LIKE to modify the Sergey bios to default to the built-in Tandy ROM boot if possible.
Does anyone know to trigger that ROM boot code in assembly?
