First post, by britain4
Good evening all, couldn’t find a hello section so... hello from the UK!
I’m doing a bit of work on a Toshiba Satellite 430CS and am currently trying to do a clean Windows install on it.
Unfortunately most of the keys on the keyboard are typing the wrong thing in both DOS and the copy of Win95 that’s on there... either strings of gibberish or just the wrong character.
Any ideas where to start troubleshooting this? I hope it’s not a hardware issue! BIOS has an option for “keyboard layout” - standard and alternative but I’ve tried both and neither work properly.
A PS/2 keyboard works just fine so I’m a bit puzzled with this one
- 486DX2-66, SoundBlaster 16, Crystal VLB graphics
- P-MMX 200MHZ, PCChips M598LMR, Voodoo 1, AD1816
- PIII 933MHz, MSI MS6119, Voodoo3 3000, SB Live!
- PIII 1400MHz, ECS P6IPAT, Voodoo5 5500, SB Audigy
Reply 1 of 7, by derSammler
Could you give an example of what character appears when pressing a certain key?
Possibilites are: num lock is on by default (BIOS option), causing many keys to do odd things on a notebook. Or a modifier key is stuck (fn, alt, strg).
Reply 2 of 7, by derringer
Hi,
I had the same problem on a netbook, due to a cup of tea.
I suggest to open the keyboard and clean it, then try an hairdryer at a safe distance (30-40 cm). Then verify if the problem disappear or evoluate.
On my netbook I saved most of the keys except 5 or 6...they are now all ok ...after 12 months
Reply 3 of 7, by britain4
Yes so for example when I press 2, the string 82q appears - what I have noticed is it seems to work in “clusters” whereby if I press either 8, 2 or q then it types 82q.
Same with w, I and a - if I type any of those it gives iwa. Same with ksz. Also many others. Seems to be in a vague pattern with the keys in a certain shape on the keyboard which to me indicates some sort of hardware issue.
I did have a spare one of these with a cracked screen but lord knows what happened to it as I’ve just moved house 🙁
Reply 4 of 7, by derringer
do you know if the machine was stored in a wet local ?
Reply 5 of 7, by cyclone3d
Sounds to me like the keyboard itself is toast, especially since an external keyboard works just fine.
You could also try reseating the cable that goes form the keyboard to the motherboard, but I really, really doubt that will fix it.
I would probably look for that spare laptop you have. I bet swapping out the keyboard will fix it.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 6 of 7, by britain4
It’s not been stored in the wet as far as I know, no. I was thinking hardware issue too since it works fine with the external board. Thanks for the replies.
I’ll be annoyed if I can’t find my spare one now, it’s a nice laptop, really good condition, battery still lasts about an hour, has CD and floppy drives (simultaneously), just the keyboard problem to sort out.
I would have a go at pulling the existing board apart and cleaning the membranes (as I have done before) but the keyboard has the track point in it so if I destroy it then it’s officialy useless as a laptop (if I can’t find my spare).
Reply 7 of 7, by britain4
Little update, I don’t know where the spare one of these I had has gone, I’ve looked everywhere for it... i do have a spare motherboard I didn’t know I had and a spare video card so I wonder if I stripped it for spares...
Anyway incredibly I’ve found a few parts sellers on eBay with the keyboards in stock so we’ll see what happens with a new one.
