First post, by britain4
I can’t run either the Win95 or Win98 setups from my HDD - copied the files over from the install disks. Running “setup” for Win95 hangs Scandisk and gives an “out of memory” message, win98 setup doesn’t start at all and just exits back to a DOS prompt.
This is on a 600mhz Celeron with 128mb memory
Any ideas?? The original hard disk boots fine on the same laptop and reports the full amount of RAM
- 486DX2-66, SoundBlaster 16, Crystal VLB graphics
- P-MMX 200MHZ, PCChips M598LMR, Voodoo 1, AD1816
- PIII 933MHz, MSI MS6119, Voodoo3 3000, SB Live!
- PIII 1400MHz, ECS P6IPAT, Voodoo5 5500, SB Audigy
