First post, by appiah4
- l33t++
Conventional wisdom seems to indicate no it does not, but there are a lot of conflicting reports on the interwebs that the T&L capabilities were unlocked in later drivers.. Can anyone confirm whether T&L works or not with the latest legacy Catalyst 6.2 drivers available on AMD's site? I suspect that would make a pretty significant difference in the card's performance if it was later enabled. Interestingly, I can't seem to find any hard evidence that it indeed was enabled..
