SB32 low FM synth volume
First post, by CkRtech
One of the funny things about diving into the SB32/AWE32 series of cards is just how many versions of DIAGNOSE, AWEUTIL, MIXERSET, etc there have been.
I have a CT3600 that went through a bit of capacitor surgery (only a couple) a year ago. I can get the 8-bit and 16-bit to get pretty loud, but FM synth is barely there. Mixer settings (across several different versions) have voice, midi up to about 90% on the sliders.
Have any of you guys experienced low FM synth volume be it with certain mixers or due to using the incorrect version of AWEUTIL - or anything else along those lines? Just hoping the cobbled together DOS drivers I am using are adequate and it isn't a hardware problem - I just wanted to run some quick tests on a bench with this guy... don't want to bother with caps if possible.
