First post, by Smelly
Im trying to get a game called out of this world to work under XP
It will run fine if i set it up for no sound when i do the setup & chose soundblaster for the sonund it will frezz.
I got vdms & did the run with vdms now i get a mesage that says A memory manager is running & will impare preformance then it gives a choice to diable sound & if i dont it will frezz.
Well i lookd in the vdms autoexec files & this is all i see
REM Free up some environment space
set classpath=
set include=
set lib=
set msdevdir=
REM Install CD ROM extensions - to enable, uncomment the line immediately below:
REM lh %SystemRoot%\system32\mscdexnt.exe
REM Install DPMI support
lh %SystemRoot%\system32\dosx.exe
Were the hell are all the sound driver lines like
SET BLASTER=A220 I5 D1 H5 P330 T6
I was expecting somthing like that to be in there?
