"Retro" Power supply
First post, by muon
Hi!
I have got some older motherboards and they need -5V 0.5A
My questions: does anybody know where I can get some retro PSU with -5V? ¿ Is there currently any power supply manufacturer that it make PSU with that voltage?
Best regards
Reply 1 of 6, by F2bnp
Are you sure you really need -5V? 😁
Reply 2 of 6, by muon
Yes, very sure
Reply 3 of 6, by F2bnp
Startech makes a couple, you didn't mention if you need an AT or ATX one so here are both:
https://www.startech.com/Computer-Parts/PSUs/ … ply~PS2POWER230
https://www.startech.com/Computer-Parts/PSUs/ … ply~ATXPOWER300
Unfortunately, the ATX one provides 0.3A instead of 0.5A. What sound card do you want to run on your system?
Reply 4 of 6, by muon
Hi!
No sound card.
The mainboard needs -5V. I have another old PSU for my 486/Pentium class machines with -5V and it works properly with that PSU. I bought a new PSU, and It doesn't work. The new PSU hasn't got -5V line.
Reply 5 of 6, by The Serpent Rider
Doubtful.
Extremely doubtful.
There's two choices: ATX-AT adapter with -5v converter or new old stock ATX PSU version ATX 1.3 or less with simple ATX-AT adapter.
Reply 6 of 6, by F2bnp
You still won't tell us what motherboard you want to use this on. I find it hard to believe that the motherboard needs -5V, but okay. I imagine the Startech AT PSU will handle the job just fine .
