DOS webserver
First post, by infania
Hey. My first post in here.
I run a webserver and FTP server in DOS. someone else running servers like that in DOS?
Experience? Do you have it online? Mine is running at http://dos.vintagepc.se/index.htm
Swedish computer hoarder
Infania Networks
https://www.infania.net/
Brain Drain Lan Association
https://www.braindrainlan.nu/
Swedish Retro Computer Association
https://www.retropc.se/
Reply 1 of 11, by Cyberdyne
Estonian DOS computer hoarder here, and I just love this what you have done 😀
Reply 3 of 11, by mrau
how much resource does it use? is it resident in the background or printing logs all the time? will it handle 10-100 users simultaneously?
is the transfer low on your isp or is the server limited by the os?
have you benchmarked this thing?
what hardware is it running on?
Reply 4 of 11, by oeuvre
Cool, you got any plans for the IRC server?
Reply 5 of 11, by gdjacobs
It's so wrong it's right. Also, good history lesson for script kiddies.
Reply 6 of 11, by infania
mrau wrote:
how much resource does it use? is it resident in the background or printing logs all the time? will it handle 10-100 users simul […]
I think it will only handle around 10 users. i have only 3 mbit out. But i feel that the webserver is the limit or DOS TCP/IP stack
Right now i run it in Virtualbox with 32mb ram and 60mb disk. but the host is dual xeon 2.4 and 2gb ram.
The first PC i run it on was a 8088 and 640kb. Just for fun.
The speed of FTP server locally is about 2mbit
Infania Networks
Reply 7 of 11, by infania
Not right now because the only version that i got to run is the one that accept only one connection at a time.
Infania Networks
Reply 8 of 11, by aquishix
I have an FTP server working on my IBM XT (true 5160 @ 4.77MHz) that I use sometimes to transfer files to it more conveniently than any other method. Had to search for a while before I came up with the perfect 8-bit NIC to use: The Intel LAN 8/16.
I don't have it exposed to the Internet, though.
Reply 9 of 11, by mrau
how fast is an ftp on a 4.7 mhz box? ever tried to find the limits when it comes to parallel connections?
why is the intel lan 8/16 perfect? were there no ther 8 bit capables around? i understand there is no such thing as offloading anyway,right?
Reply 10 of 11, by aquishix
I mean...slow. 😉 If you're really curious, I could hook it up again and do some benchmarking for you. But I'm pretty sure that the network connection is not the bottleneck. The system itself just can't conduct fast I/O across an 8-bit bus, no matter how awesome the drive or device is that's plugged into it. So maybe that answers your question. I should verify this, but I think it's pretty much as fast as copying files from an MFM hard drive to another drive, or perhaps as fast as copying files to/from an SSD hooked up to an XT-IDE card.
The Intel LAN 8/16 is perfect/awesome for five reasons.
1) The packet driver works perfectly in DOS 5.0 on an XT.
2) The cards are fairly common. I was able to purchase 3 of them at reasonable prices on eBay.
3) You can set the hardware resources the card uses (IRQ/"interrupt") with a very convenient program that was designed to flash the EEPROM built into the card itself.
4) Even though it's a 16-bit ISA card, it works when plugged into an 8-bit bus slot on the XT. It even has a special setting that can be changed in its EEPROM to force it to operate in 8-bit mode, meaning it doesn't even try to use the 16-bit extension on the card's bus connector.
5) It has a 32-pin EEPROM socket that can house a boot ROM, but that boot ROM doesn't have to have anything to do with PXE booting. I've got a re-flashed chip from one of my XT-IDE cards plugged into such a socket, and it enables me to use large/LBA/modern SSDs on any standard 16-bit IDE host adapter that's also plugged into the system. =)
Reply 11 of 11, by mrau
thanks for the feedack - i obviously forgot there is no caching going on there;
i asked about performance because the png file is loading very very slowly, i wondered what could cause this;
also just noticed that it is Your specific NIC model that was tested with this server - zing, i guess;
anyway i don't want to occupy Your time with this, but thanks for the kind offer; i guess i'll try to get this thing into some VM and see what it can do - i do wonder if an XMS/EMS cache would help performance visibly (nerd alarm); another thing i was wondering about: does the task of preparing packets keep the cpu from handling disk reads at max performance and how much delay does the file system induce;
