First post, by The Serpent Rider
For some strange reason both ISA Cirrus Logic video cards in my possession (5402 and 5420) just hang on their boot screens when paired with ASUS P3B-F motherboard. Is it particular ASUS quirk or just PIIX4E south bridge problem on any motherboard?
Reply 1 of 14, by derSammler
Could be that the maimboard does not provide the 14.3 MHz clock on the ISA bus? I've read that CL cards won't work then.
Reply 2 of 14, by Tetrium
I suppose one can check this from inside the BIOS? I'm not too familiar with ISA graphics cards and the ones I did try in an ISA slot in a BX board seemed to provide an image.
My retro rigs (old topic)
Report spammers here!
Reply 3 of 14, by appiah4
It could be an IRQ conflict? Have you tried reserving IRQ 9 and if that fails IRQ 2 for Legacy ISA in BIOS.
Reply 4 of 14, by The Serpent Rider
I'll try that.
Reply 5 of 14, by derSammler
No, you need to look for an 14.3 MHz crystal on the mainboard. Many manufacturers dropped that at some point.
Reply 6 of 14, by Tetrium
Cheers 😀
Reply 7 of 14, by The Serpent Rider
Tinkering with IRQ9 didn't help and IRQ2 can't be reserved. With 5402 things got even worse - card couldn't boot up properly.
Reply 9 of 14, by The Serpent Rider
Interesting, but in my case both cards can display picture.
Reply 10 of 14, by The Serpent Rider
So I've tried another VGA card, this time even older and packed with oscillators - Jovian Logic RUBY 451. To my surprise even that card still hangs up on the initial screen with VGA card info.
Reply 11 of 14, by Great Hierophant
I am almost sure I tried an Adlib or an early Sound Blaster in my ASUS P3B-F and they worked. The early FM/OPL2 cards lacked an onboard 14.3MHz oscillator and won't work without one from the ISA connector.
Reply 13 of 14, by appiah4
Have you checked the ISA slot for corrosion? Do you have a second ISA slot you can try on the Motherboard, preferrably one that does not share resources with the PCI bus?
Reply 14 of 14, by The Serpent Rider
Trident 8900D and various sound cards are working fine, so ISA slot itself is not a problem.
