Reply 480 of 669, by Joseph_Joestar
- l33t++
asdf53 wrote on 2024-02-25, 08:53:I'm trying to get table fog enabled on my Radeon 8500 LE under Windows 98, but I'm having no luck so far. I tried drivers from 2001-2003, also followed the guide from this thread where someone had enabled it on his Radeon 8500 using Rage3D tweak, but it did nothing for me.
Try uninstalling your current drivers and then install Catalyst 6.2. After that, apply this registry tweak. That worked for me on a Radeon 9250, which is relatively close to your 8500 in terms of architecture.
Under Windows 98, table fog doesn't work on Radeons by default, but it can be enabled with a registry setting. Can someone confirm this?
This is generally correct, but in some games like Shadows of the Empire, table fog will not work on Radeon cards under Win9x even with the registry tweaks applied. It's an unreliable fix.
Under Windows XP, it works out of the box with newer drivers
Correct. You just need Catalyst 7.11 or newer. However, note that those drivers aren't compatible with some older Radeon cards.
And here's the DirectX 6 SDK that contains the dxview.exe to check if 8-bit paletted textures are supported. You don't need to install the SDK, use 7zip to extract "bin\DXUtil\dxview.exe" from the installer archive.
I found that to be an unreliable testing method. On some cards, it would report a feature as supported (likely due to driver fakery) but in actual games it wouldn't work. Use the Final Fantasy 8 demo for a quick and easy test of paletted textures.
