First post, by Atom Ant
I'd like to build an old computer for Windows 3.1, with the following specs;
-Asus P5A Super Socket 7 motherboard,
-Pentium 233MHz MMX,
-3dfx Voodoo 1 6MB PCI,
-Matrox Millenium 4MB AGP (yes I'd like to use the AGP version, if the motherboard has that slot)
-Windows 3.1
However my concern is that I read somewhere AGP support is only from Windows 95 Service Pack 2. If so is there any trick or mod to make work with Windows 3.1?
My high end of '96 gaming machine;
Intel PR440FX - Pentium Pro 200MHz 512K, Matrox Millenium I 4MB, Creative 3D Blaster Voodoo II 12MB SLI, 128MB EDO RAM, Creative Sound Blaster AWE64 Gold, 4x Creative CD reader, Windows 95...
Reply 1 of 13, by squiggly
AGP cards are mapped in by the BIOS. The OS has no concept of an AGP card. Although the driver might as far as 3D goes. But for 2D and VGA...you could use it with DOS. I have used a variety of AGP cards with DOS.
Reply 2 of 13, by derSammler
No AGP feature will work (the Millenium has none, afaik, anyway), so Windows will just see it as a standard VGA card.
Reply 3 of 13, by Jo22
As squiggly and derSammler said, there's noo need to worry about AGP. 😀
If I'm not mistaken, AGP is basically a super set of PCI (among other things AGP has GART, a higher bus speed, etc).
An AGP graphics card will appear as a normal PCI device to AGP-unaware OSes.
Even older systems, such as DOS/Win3.1, without any knowledge about PCI, will still see it as a generic VGA device.
On such old OSes, the PCI-/AGP-specific parts (addresses, INTs, etc) are handled by the vendor drivers (if installed).
You're lucky I've seen Matrox drivers for Windows 3.1. 😀
One of them is a graphics driver for Millennium/Mystique, maybe it works.
http://win31.de/edrivers.htm
Reply 4 of 13, by keropi
I use an AGP Trio3D/2x with 3.11 like others said it works fine. If your card also has 3x drivers then even better - you won't be stuck with the generic vga driver.
Reply 5 of 13, by Ampera
On the topic of 3.1 drivers, you might get lucky and can use Super VGA or XGA modes.
Reply 6 of 13, by McKie1
Cool system specs.
We are currently in the process of building something similar 😉
Reply 7 of 13, by derSammler
Looking at the specs: is there a reason why you don't install Win95? With a 233-MMX and Voodoo1, you can play lots of games from up to 1997/8 without problems. But not when using Win3.1. The hardware is a bit wasted for that, especially the 6MB Voodoo1, which not a single 3dfx-ready DOS game can make use of (they are designed for 4 MB). Not that there are that many DOS games with 3dfx support at all, anyway. Same goes for MMX, which neither DOS nor Win3.1 can use. Such a system screams for games like pod, NFS2SE, and the like.
Reply 8 of 13, by Atom Ant
Thanks for the lots of reply and really good to know the AGP card will work, hopefully with a hihger resolution, once the proper driver is installed. The Win31.de seems also an useful website.
DerSammler:
It is also my concern how well can i utilize my Canopus Voodoo 1 6MB with Win 3.1? And NFS II SE is on my list to play. Loosing MMX also not good, i did not think for that. However for Windows 95 I plan to build an another computer with Voodoo2 SLI and Pentium II overdrive 333MHz.
Reply 9 of 13, by fitzpatr
To be honest, using a P5A with a Pentium MMX seems like a bit of a waste. The P5A is one of the highly prized Super Socket 7 ATX boards. Whereas most Socket 7 boards will be capable of working with a Pentium MMX and their 66MHz FSB, most cannot make full use of a K6-2+ or K6-3+ and their 100MHz FSB.
Additionally, as mentioned above, a Pentium MMX tends to be more at home on a Windows 95 or 98 system.
In effect, you're using an OS from 1992 on a CPU from 1996, on a motherboard from 1998. This is certainly your choice, but it may introduce some compatibility issues.
MT-32 Old, CM-32L, CM-500, SC-55mkII, SC-88Pro, SC-D70, FB-01, MU2000EX
K6-III+/450/GA-5AX/G400 Max/Voodoo2 SLI/CT1750/MPU-401AT/Audigy 2ZS
486 Build
Reply 10 of 13, by KCompRoom2000
But I already have a Celeron-433 for Windows 95, so replacing Windows 3.11 with 95 on my Pentium-233 build will result in having two Windows 95 rigs and zero Windows 3.1x rigs. Should I just order a Pentium non-MMX 200 MHz CPU and get it over with?
[realizes that the P1 rig is dual-booting with Windows NT which supports programs that benefit from MMX CPUs] Yeah, I'm not so sure, I guess I should've thought twice before posting. 😦
Atom Ant wrote:
DerSammler:
If you insist on running both Windows 3.1x and 95 on one system, what's stopping you from dual-booting? There are some DOS games that support the Voodoo but nothing for Windows 3.x, so it's not a total waste for DOS, I believe the Windows 95 boot loader allows you to dual-boot with a previous version of DOS so if you have MS-DOS 6.22 w/ Windows 3.1x on one partition and 95 on another, you have the option of dual-booting so you'll have an excellent system for covering two generations of Windows games.
Reply 11 of 13, by Atom Ant
There is no 3dfx game for Windows 3.1 at all? Would not be possible to add the directx 5 into windows 3.1 and run the NFS 2?
I am thinking now also to drop the mmx option and just buy a regualar pentium 200mhz. My other system which is pentium 2 overdrive that knows the mmx anyway. However i think i would stay with Asus P5A, it helps to bring the best out of Pentium 200mhz.
Reply 12 of 13, by derSammler
No, DirectX is Win95 and up only. Win3.x had GDI and WinG (predecessor of DirectX) only. Also, Windows 3.1 can not execute 32-bit programs anyway, unless you install Win32s - but even that won't allow you to run Win95 games.
Reply 13 of 13, by Atom Ant
I see ,thanks for the reply. I need to rethink now lots of things, because basically Windows 3.1 cannot run any more games than DOS.
