First post, by buckeye
Is there anyway to connect the front case panel audio connections to this card? If not I'll have to look into some headphones with a longer cord.
Foxconn Q45M E8400 Core2 Duo 3GB DDR2 800 BFG Geforce 7950GT 512MB X-Fi Xtreme Music 500W XP SP3
Intel SE440BX P3 450 256MB 40GB Voodoo 3000 16MB SB 32pnp 350W 98SE
MSI x570 Gaming Pro Carbon Ryzen 3700x 16GB DDR4 Zotac RTX 3070 8GB WD Black 1TB 650W
Reply 1 of 6, by ZanQuance
It's possible to get going, but by default the original drivers do not route audio through the expansion headers.
Which front panel connector were you wanting to use? The stock motherboard one cases come with? This might be doable so long as they want a digital signal and not an analog one. Otherwise you will need a DAC on the front panel connector.
So 2 Questions:
Which front panel do you wish to use?
Which Aureal Vortex 2 card are you using?
Reply 2 of 6, by buckeye
ZanQuance wrote:
It's possible to get going, but by default the original drivers do not route audio through the expansion headers. Which front pa […]
So 2 Questions:
Stock mobo connection
8830 model
Reply 3 of 6, by ZanQuance
There are no analog outputs on the Vortex 2 external connectors for a stock mobo connection.
All Vortex 2 cards are model 8830, do you have an MX300? SQ2500? Montego II? They each have a different connection topology.
Reply 4 of 6, by buckeye
Turtle Beach I believe, not at home so can't check on the serial/model number. It's an "angular" card not a rectangle like diamond if that helps.
Reply 5 of 6, by ZanQuance
Sound like you have the popular Turtle Beach Montego II.
You would need a front panel connector that supports decoding I2S or S/PDIF input signals to have it work. I don't know of any off hand.
Reply 6 of 6, by buckeye
Thanks ZanQuance, it just means I'll have to get some new headphones with a longer cord no big deal.
