What SCSI cable?
First post, by Camtheman
So I’ve got this SCSI adapter, what cable/adapter do I need to connect “normal” 50 pin SCSI drives?
https://www.amazon.com/IBM-11H7660-DIFFERENTI … R/dp/B016YKFLQM
Early 90s: IBM PS/2 Server 95/A, Pentium 66, 16MB RAM, XGA-2, IBM SCSI Corvette, SCSI2SD, 3 Com EtherLink III MCA, Resound 2 AdLib MCA
Late 90s: Micron Millenia MXE, ABIT VH6-II, Coppermine 1ghz, 1024MB, Voodoo 5 5500 PCI, GUS Max 2.1, 128GB SATA PNY SSD
Reply 1 of 3, by Disruptor
You first need a converter from Differential-Wide-SCSI (HVD!) to Single-Ended-Wide-SCSI.
Then you need a converter from Wide-SCSI to Narrow-SCSI.
Then you need a narrow SCSI cable.
Reply 2 of 3, by dionb
Note that the 68p wide to 50p narrow converter is simple & dirt cheap, but HVD to SE is non-trivial (i.e. possibly expensive but certainly rare). TBH you'd be better off finding HVD drives. 4.3GB Seagate HVD was particularly common.
LVD is backwards-compatible with SE, HVD was not...
Reply 3 of 3, by Camtheman
Apparently there's some sort of weird card edge connector (like you'd see on 5.25 floppy drives) for 50 pin SCSI on this card...?
http://ohlandl.ipv7.net/IBM_SCSI/SCSI-DFW.htm … ernal_Connector
https://www.cs-electronics.com/50-pin-internal-scsi-cables/
Wonder if that would work. Cables seem kind of rare tho... hmm
