First post, by Smack2k
- Oldbie
Trying to revive an old Packard Bell Legend 300CD
When I boot up the system it reads the memory fine, asks to hit F1 to enter bios. If I hit F1 there it says entering BIOS, finishes up the boot process, but then gives the following errors: CMOS battery dead, memory decreased,
Then prompts to hit F1 for setup or ESC to boot. If I leave it alone it will wait for a choice until I make one, doesn’t freeze, hitting ESC to boot will boot off the floppy drive fine and I can even navigate the HDDs once the boot disk finishes loading. Hitting F1 however does nothing and the system freezes, doesn’t enter BIOS and does nothing. Keyboard is useless after this, cant reboot, can’t do anything
Could the dead CMOS battery be causing this issue? Or could it be something else? I’ve pulled everything and only booted with keyboard / mouse / monitor / mobo and no change to the issues
