First post, by xjas
I have a Seagate 500GB+8GB hybrid drive that the spinning disk portion of has apparently died. I could actually use an 8GB SSD for something & I don't feel like waiting a month for a CF card or SD adapter from Ebay. Is it possible to disable the disk portion of this thing & make it act like a dedicated SSD? Can SeaTools do this?
Reply 1 of 6, by cyclone3d
It is Seagate.... Seagate IS THE DEVIL. If you buy a Seagate drive, it will generally fail within 1-2 years.
In any case, there is no way to directly access the SSD portion of an SSHD.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 2 of 6, by Jo22
Reminds me of the old German pun "Sea-gate, sea-gate nicht." (which sounds like "Sie geht, sie geht nicht." English: She runs/works, she runs/works not). 😉
Reply 3 of 6, by Anonymous Coward
Seagate made some pretty decent SCSI drives, but I admit I hae not had very good luck with their ATA drives. I find the 1-2 year estimate to be pretty accurate.
Reply 4 of 6, by xjas
I've got some from 2008-2011 that seem to be going fine with no issues, but they're not exactly in hard-core daily use. That's not really the subject of this thread though.
This specific model of SSHD came in a lot of mid-range Lenovo laptops, and seems to be well known to tank in exactly the way mine did.
Reply 5 of 6, by clueless1
No, not possible. The 8GB is really a very large disk cache and cannot work independently of the platters.
Reply 6 of 6, by xjas
Yeah, I was hoping there would be a firmware hack or something out there though. My google skills are turning up nothing.
The damn thing still boots fine, and you can use it right up until it runs out of 'cached' data and brings the whole system down with an eldritch screech. So it is capable of running as an SSD on its own to a certain extent. No drive should ever make that noise though.
