First post, by Megadisk
EDIT: looks like changing the emm386 line and adding "NOEMS" at the end did the trick.
I have a new to me IBM PS/2 model 50z (286). It came with some software already installed including MS-DOS 3.30 & Win3.1. The only thing I've done so far is to install a 386sx upgrade module because I'd like to use an OPL2LPT external parallel sound card and the 286 can't do it.
Now, to use the OPL2LPT I added a newer "EMM386.exe" (including config.sys line) as this is required in order to work but I'm having memory problems. I first have to enable the OPL2LPT driver and it works just fine but as soon as I run a game problems happen. When loading Wolf3d for example, as soon I load a level, it quickly kicks me out with the error: "PM_Pleload: Exceeded XMS Pages".
The PC board has a 1MB simm but there is MCA memory card that has a couple of populated ram slots. The initial ram test displays that I have 4096Kb altogether.
My MS-DOS 3.30 is a bit rusty and I'd like to keep it if possible. Any help or ideas would be much appeciated!.
This is what config.sys looks like:
SHELL=C:\DOS\COMMAND.COM C:\DOS\/P
FILES=30,0
BUFFERS=30,0
LASTDRIVE=K
DEVICE=C:\WINDOWS\HIMEM.SYS
DEVICES=C:\DOS\EMM386.EXE
STACKS=9,256
And autoexec.bat :
C:\WINDOWS\SMARTDRV.EXE
ECHO OFF
CLS
C:\WINDOWS\mouse.COM /Y
PROMPT $p$g
PATH=C:\;C:\DOS;C:\WINDOWS
SET TEMP=C:\WINDOWS\TEMP
CLS
DIR
