First post, by samtam90
When I try to run Armada with Dosbox, the game gives me this error message: "EMS is not VCPI compliant".
What does it means? And what can I do? 😕
Reply 1 of 2, by Qbix
Rank DOSBox Author
DOSBox Author
did you read the first post in this thread ?
 	DO NOT POST QUESTIONS ABOUT DOSBOX HERE
The answer to your question. Turn ems off
Water flows down the stream
Reply 2 of 2, by samtam90
It works. I've found the solution in the Dosbox site.
