First post, by Tmp2k
So I reflashed a GA-8I865GME-775-RH rev6.6 as it wasn't' recognising Core2 CPUs and I believe the BIOS is corrupt. As there is no POST of any kind, just a message indicating that the BootBlock is searching the HDD for a BIOS image.
Apparently, the BIOS backs up automatically to a hidden section of the HDD every boot in case it gets corrupted. In this state, you can't do anything as the BIOS is corrupted, so there are no options.
The problem is I can't seem to find a way of putting the BIOS image onto the HDD and this feature is totally undocumented. The BIOS chip is soldered directly to the board so I cant reflash or replace it manually.
I've found other threads where people have tried to solve this problem. Gigabyte are no use, and someone got as far as reverse engineering the BootBlock program but didn't figure out where it was looking for the BIOS image.
Any ideas?
