First post, by GabrielKnight123
Im trying to install a CD/DVD drive for a 386 but the Bios does not automatically detect it probably because of the age of the Bios, there is an option to select cylinders/heads/sectors but all the drives I have here have no info about the C/H/S. The motherboard I have only has ISA busses and im using an I/O card to get a single IDE working with the HDD as Master and the CD/DVD drive to Slave, the HDD works but the CD/DVD drive does not get detected at boot or in the Bios im guessing I need a special I/O card or some settings in the Bios.
Reply 2 of 9, by Jo22
Since it is a 386, you can use a Win98SE start-up floppy (or emergency floppy) for testing.
It is bootable (has DOS 7.1) and contains drivers for both IDE and SCSI based CD/DVD drives.
You can't read DVDs with that, of course. Just CDs of any kind.
Edit: I assume, you've got a 1.44MB floppy drive in that PC.
If not, there are these Gotek floppy emulators which can be found for cheap..
Reply 3 of 9, by GabrielKnight123
Thanks guys I got it working and its a DVD drive which surprises me as its way newer than the 386
Reply 4 of 9, by ultimate386
Are you using an add-in IDE controller card in that 386? I would be surprised if a CD/DVD drive worked with any IDE interface built into a 386 board.
AMD386/IIT387DX40, 32MB, ATi Mach64, AWE64
Compaq Prolinea 4/33, 32MB, Tseng ET4000, PAS
AMD X5, 64MB, S3 Virge/Voodoo1, AWE64
AMD K62+550, 256MB, Voodoo3, AWE64 Gold
P3 1.2Ghz, 512MB, Radeon 7500/Voodoo2 SLI, SB Live!
Reply 5 of 9, by yawetaG
It merely needs a driver to work, detection by the BIOS is not required (of course, booting from the CD/DVD drive ain't possible).
Reply 6 of 9, by ultimate386
Yes, I am aware that CD/DVD drives won't be detected by older bioses. I was under the impression though that ATAPI devices would not work on the original implementation of the ATA/IDE interface, even with a driver. In fact, I've dealt with more than a few systems where this has been the case. My Compaq Prolinea, for example, will absolutely not work with a CD/DVD drive on its built-in controller (tried for the first time in 1996, I think!).
Reply 7 of 9, by bjwil1991
PloP boot loader can do just that. It wasn't until the Pentium systems (I'd say 1995 or so) supported the booting from a CD/DVD.
Reply 8 of 9, by talamavnn
GabrielKnight123 wrote on 2018-04-13, 14:42:
Hello, can you help me? I cannot setup DVD drivers on 486!
Reply 9 of 9, by MikeSG
In DOS 6.22..
In autoexec.bat you need to add:
"MSCDEX.EXE /D:cdrom"
In config.sys you need to add:
"DEVICE=cd1.sys /D:cdrom"
If cd1.sys doesn't work, try cd2.sys, cd3.sys, cd4.sys.
It only works with some types of CD/DVD ROM drives.
Windows should automatically detect it regardless.
You might find the best CDROM is a 4x or less on a 386 otherwise it might spin up/down constantly hunting for a speed.
