First post, by dosgamer
- Newbie
Anyone ever done this? I had to on this card. It wouldn't output any sound. On closer inspection, I found that the SMD resistors on the Zobel network on the LM386 outputs had their tops blown off, and the SMD capacitors looked overheated. 😐 I don't even. I desoldered the the two LM386 amplifiers and they were dead as well. Luckily, the ES1688 chip itself was fine. I jumpered the AOUT_L and AOUT_R pins directly to the output jack via two 10uF coupling capacitors as per the datasheet. Now it's a proper line out. It should improve the sound quality as the cheap amplifiers used on sound cards are usually crappy and noisy.
Coppermine Celeron 800 @ 1.12GHz (8x140) - Asus P2B Rev. 1.12 - 256MB PC133 CL2 - Voodoo5 5500 AGP - SB AWE64 CT4520 - Roland SCC-1 - Intel Pro/1000GT - 1.44MB Floppy - ATAPI ZIP 100 - 120GB IDE - DVD-ROM - DVD-R/RW/RAM - Win98SE
