problem with Powerslide
First post, by willow
I use dgvoodoo 2.55 and windows 10 and powerslide 1.04
1) With dgvoodoo2, i can't select resolution superior to 640x480 in ingame option menu and specular option is greyed. (I can force resolutuion in dgvoodoocpl and it works but specular doesn't work). I have tried all options in dgvoodoocpl.exe (voodoo2,voodoo3, other great) and same thing
With nglide, I can select resolution betwween 640x480 and 1280x1024 and specular can be turn on
In readme
"1. Added features (since v1.01)
- Added the ability to perform GameGauge speed-profiling tests, via a
command-line option.
- Support for higher resolution modes on the Banshee and Voodoo3 graphics
cards.
2. Bugs fixed (since v1.01)
- Voodoo3 cards are now detected as a Glide card, not a Banshee. This means
that specular will work on a Voodoo3."
2) If I want use direct3d mode, i have copied ddraw.dll. The dgvoodoo watermark appears ingame but when I want select the different renderer in graphic option, there are only software and nglide, not direct3d.
Reply 1 of 2, by Dege
Thanks, indeed.
As for D3D, I have never managed to get that working. As if the game didn't have support for that all.
Reply 2 of 2, by ZellSF
Random bump, maybe after two years you have some new ideas why this doesn't detect Direct3D? Or specular (Zeus says it checks frame buffer version)?
