Dynamic core optimization
First post, by awgamer
I'm still blocked with the issue. Anyway, the point was to do some optimizations to the dynamic recompilation(risc_x86.h,) less bloated in cache and fewer instructions processed, see attached. Optimizations here would diminish cpu spikes, smooth things out, and help in possible thrashing corner cases. There are some spots in decoder.h that could be tightened up as well in the same way like the dyn_read/write_x, which get touched a lot.
Reply 1 of 26, by Qbix
Rank DOSBox Author
DOSBox Author
Interesting, I would have assumed that the compiler did some of these on its own (given the inline and the greater picture)
but I checked the dynrec core x64 and noticed that for smaller functions it is "smart", but for the more complex things (gen_function_raw and such, which is inlined itself), it really starts doing one byte at the time and increase the pointer through a move, increase, move back operation.
Water flows down the stream
Reply 2 of 26, by awgamer
Yeah, my intent was/is to do the gcc option of spitting out its assembly step to see the difference or not in the code it generates, know for sure at that point. Sounds like this is how you checked?
Reply 3 of 26, by Qbix
Rank DOSBox Author
DOSBox Author
yeah, I used
objdump -Mintel -dS core_dynrec.o > test.asm
But it is a bit messy to read due to the optimized code.
I could have used that gcc option to output it directly, but this is easier given that the object files are in my tree normally
Reply 4 of 26, by awgamer
Yeah, gcc asm output is cryptic but a before and after compare is enough, mostly, for me to follow along. Hopefully I'll work out this annoying permissions issue to play with this myself. Speaking of cryptic, I find some of the changes I did more readable/less spaghetti, shorter than the original, but maybe that's just me:)
Reply 5 of 26, by Qbix
Rank DOSBox Author
DOSBox Author
It's easier to read with the -Mintel, but the interlinked source (the S) is sometimes a bit off.
Reply 6 of 26, by awgamer
Another tweak, can pull "if (!dsr2 && (ddr==dsr1) && !imm_size) return;" into the "if (!imm && (gsr1->index!=0x5))" path, no need to do the check for imm_size 1 & 4.
static void gen_lea(DynReg * ddr,DynReg * dsr1,DynReg * dsr2,Bitu scale,Bits imm) {
GenReg * gdr=FindDynReg(ddr);
Bitu imm_size;
Bit8u rm_base=(gdr->index << 3);
Bit8u index;
if (dsr1) {
GenReg * gsr1=FindDynReg(dsr1);
if (!imm && (gsr1->index!=0x5)) {
if (!dsr2 && (ddr==dsr1)) return;
imm_size=0; rm_base+=0x0; //no imm
} else if ((imm>=-128 && imm<=127)) {
imm_size=1;rm_base+=0x40; //Signed byte imm
} else {
imm_size=4;rm_base+=0x80; //Signed dword imm
index=gsr1->index;
} else {
imm_size=4;
index=5;
if (dsr2) {
GenReg * gsr2=FindDynReg(dsr2);
cache_addw(0x8d|(rm_base+0x4)<<8); //0x8d=LEA | The sib indicator
Bit8u sib=(index+(gsr2->index<<3)+(scale<<6));
cache_addb(sib);
} else {
cache_addw(0x8d|(rm_base+index)<<8); //LEA | dword imm
switch (imm_size) {
case 0: break;
case 1:cache_addb(imm);break;
case 4:cache_addd(imm);break;
ddr->flags|=DYNFLG_CHANGED;
Reply 8 of 26, by awgamer
I can compile now, took a reinstall, w7 was borked. Tweaks work, /w a touch up here and there, negligible performance change, though the binary is a K smaller and saved ~100k on mem usage(varies, just tracking /w task manager,) which I've been trading for inlining xyz. Need to get asm output going(objdump isn't working for me currently) and profiling to see what's going on.
Reply 9 of 26, by Qbix
Rank DOSBox Author
DOSBox Author
I'll be interested what you come up with.
I did something similar as you did for the dynrec core and it got a lot smaller indeed, but noticed no performance changes (which isn't too surprising as the asm that dosbox executes is unchanged)
Reply 10 of 26, by awgamer
Refresh my memory on invoking diff to output the correct format and I can upload what I have now, warts and all. I used the svn tar.gz from here: https://www.dosbox.com/wiki/Building_DOSBox_with_MinGW
Reply 11 of 26, by Qbix
Rank DOSBox Author
DOSBox Author
extract the source a second time (folder name dosbox-org)
and then run in the folder that contains both yoursource and the original source
diff -u dosbox-org/src/cpu/core_dynamic/decoder.h yoursource/src/cpu/core_dynamic/decoder.h > mypatch.txt
Reply 12 of 26, by awgamer
Changes have been more than to just decoder.h, but confined to core_dyn_x86 dir.
    mypatch.txt
    40.51 KiB
    396 downloads
Reply 13 of 26, by awgamer
did another tightening to the guys in decoder with these:
cache_addd(0x52|(0x50+genreg->index)<<8|0xe850<<16);
to
cache_addd(0xe8505052+(genreg->index<<8));
getting rid of two ors and a shift. chris's 3d bench liked it, it seems, 1001 vs 957. error of margin? like I said, I need to get asm output and profiling going.
Reply 14 of 26, by awgamer
Reduced the binary by 8k now, mostly from changing ifs & switches /w repetitive function/method calls with local vars and calling once. Applied the optimized bound checking from the mixer to the mouse handler. The optimization in gen_call_function I had commented out working now.
    my.diff
    117.62 KiB
    372 downloads
Reply 15 of 26, by awgamer
From the asm gcc is generating, they are faster, not just a size reduction of the binary. so yeah, fewer cache_addx is betta.
static void gen_return(BlockReturn retcode) {
gen_protectflags();
if (retcode==0) {
cache_addd(0xc3c03359); //POP ECX, the flags
// cache_addw(0xc033); //MOV EAX, 0
// cache_addb(0xc3); //RET
} else {
cache_addw(0xb859); //POP ECX, the flags
// cache_addb(0xb8); //MOV EAX, retcode
cache_addd(retcode);
new:
__ZL10gen_return11BlockReturn.part.5:
movl __ZL5cache+16, %eax
movl $-1010814119, (%eax)
addl $4, %eax
movl %eax, __ZL5cache+16
ret
__ZL10gen_return11BlockReturn:
subl $4, %esp
cmpb $0, __ZL6x86gen
jne L247
L244: // -1xmov,2xlea
testl %eax, %eax
je L248
movl __ZL5cache+16, %edx
movl $-18343, %ecx
movl %eax, 2(%edx)
leal 7(%edx), %eax
movw %cx, (%edx)
movb $-61, 6(%edx)
addl $4, %esp
ret
L248: // +1xadd,1xjmp, -2xmov,1xlea,1xadd
addl $4, %esp
jmp __ZL10gen_return11BlockReturn.part.5
L247:
movl %eax, (%esp)
call __ZL16gen_protectflagsv.part.2
movl (%esp), %eax
jmp L244
old:
.cfi_startproc
subl $4, %esp
jne L266
L262:
testl %eax, %eax
leal 1(%edx), %ecx
movl %ecx, __ZL5cache+16
movb $89, (%edx)
je L267
Show last 27 lines
	leal	1(%edx), %ecx
movb $-72, (%edx)
movl %eax, (%edx)
leal 4(%edx), %eax
leal 1(%eax), %edx
movl %edx, __ZL5cache+16
movb $-61, (%eax)
addl $4, %esp
ret
L267:
movl $-16333, %edx
movw %dx, (%eax)
addl $2, %eax
leal 1(%eax), %edx
movb $-61, (%eax)
addl $4, %esp
ret
L266:
movl %eax, (%esp)
movl (%esp), %eax
jmp L262
Reply 17 of 26, by awgamer
Added a cache_add3, which adds three bytes to the cache doing a dword move and inc the pointer by 3, replacing the addb + addw for those cases.
    m3.diff
    157.91 KiB
    400 downloads
Reply 19 of 26, by awgamer
Oh yeah? Well I've got cache_addq & cache_add7 working preliminarily and currently implementing the optimizations 😀
edit: Well, they work, but it seems like doom bench is getting slower as I add 64 bit moves.
