Red Alert missing a CD
First post, by scarlac
Hi,
My problem is that I am unable to run command & conquer - Red Alert. Whenever I run the game RA tells me to insert the CD, but I have already mounted my cdrom, with the proper arguments (-t cdrom ,etc.)
My setup is:
Debian Linux 2.4.26
DOSBox v. 0.61
And my autoexec section in ~/dosbox.conf looks like this:
@mount c /home/seph/games
@SET LASTDRIVE=Z
@mount -t cdrom d /cdrom -usecd 0 -L CD1
@mount -t cdrom e /cdrom1 -usecd 1
I have tried without specifying a type but nothing seems to work 🙁 When I installed I installed without the -usecd 0 and -L swtiches, and it worked fine, the above setup was a result of trying to different switches and combinations.
Apart from that, the installer works fine, and I have got theme park working under dosbox on this machine so I am a bit mystified 😢
I tried both CDs, same result. They are originals and I have gotten them to work on my laptop under Windows XP Home
Reply 1 of 1, by Qbix
Rank DOSBox Author
DOSBox Author
dosbox it's cdrom features emulation isn't totally finished. especially under linux.
You could try if you can get it running in dosbox under winxp
I will move this topic to the dosbox forum
Water flows down the stream
