First post, by weldum
Hi, i have a pcchips motherboard that has a Duron 850 soldered on, the board is stable and runs well.
that said, it has a rather serious problem.
by default, it came overclocked, the processor report's itself as a Duron 892.5, with FSB being 105 and multiplier being 8.5
in the bios there are no settings for this, also i've looked at the crystal oscillators in the board, but all seems to be right, comparing to a another board that has socket and the FSB selectable (is from another brand also)
it doesn't have stability problems nor heat problems, the only real problem is the AGP and PCI slots being overclocked, making that some videocards aren't working at all, while others work just fine.
i think that dumping the bios, modifying it and reflashing should solve the problem, but i know nothing about how to do.
maybe someone can help me in this, or by giving me some ideas, because i want to use it better, the crappy integrated SIS video is making me crazy.
Thanks.
DT: R7-5800X3D/R5-3600/R3-1200/P-G5400/FX-6100/i3-3225/P-8400/D-900/K6-2_550
LT: C-N2840/A64-TK57/N2600/N455/N270/C-ULV353/PM-1.7/P4-2.6/P133
TC: Esther-1000/Esther-400/Vortex86-366
Others: Drean C64c/Czerweny Spectrum 48k/Talent MSX DPC200/M512K/MP475
Reply 1 of 15, by Zup
What about dumping the BIOS (to have a backup) and then flashing an official BIOS?
I'm selling some stuff!
Reply 2 of 15, by dionb
Which PC Chips board are we talking about?
Also, 105MHz is a tiny overclock, the PCI bus is only running at 35MHz and AGP at 69MHz. That's out of spec, but only barely so. Most cards can handle 37.5MHz PCI effortlessly (and it's usually IDE/SCSI controllers that cause problems before video cards), and AGP speeds of 88MHz are rarely a problem. It's theoretically possible that a single marginal card might not work, but if you say multiple cards are showing problems I'd seriously doubt that the higher clock itself is the cause of your issues. Given the period this board is from I'd start checking capacitors first...
Reply 3 of 15, by weldum
yes, but don't know how to dump the bios, and where to get a newer one, also i've found a web page where a guy modifies the bios to replace the old Novell RPL with the newer Intel PXE, and where to find the files. but he doesn't explain how to dump the bios.
sorry i forgot to say that
it's a PCChips M810LR7, with a SIS 730S chipset, and locked to a 2x AGP implementation apparently
the cards tested are:
Trident 3DImage 9750: garbled screen and crashes in windows
ATi Rage Pro Turbo (Xpert98): Perfect
SiS 315 Pro: Perfect
S3 Savage 4 Pro: Lot of crashes and random reboots
GeForce 2 MX400: Perfect
GeForce 4 MX4000: crashes and the driver can't be installed
GeForce FX 5200: Works well in DirectX mode, the OpenGL ICD doesn't install, while in other machines with the same OS, driver, etc. everything works fine
these cards are all AGP, i've tested some 2D PCI cards but they don't seem to fail
all cards works perfect on a normal system without overclock or conflictive chipsets/AGP implementations, and in various AGP settings when supported (1x, 2x, 4x, 8x)
i've changed the PSU also, changed RAM, changed HDD (who knows) tested all bios settings and nothing
what works works perfect, and the others have some degree of failure
i've also tested with several drivers and os'es but nothing seems to fix it
Reply 4 of 15, by Zup
Usually, the same program that does the BIOS flashing lets you save a backup. I remember some thread about a pcchips website backup (but I can't find it). Google your motherboard model, maybe you can find a BIOS replacement somewhere.
Reply 5 of 15, by weldum
i think i will have some testing, because here in Argentina, motherboards with the processor soldered and (sometimes) overclocked were very common in the 1999-2006 period, and there are a lot of variants here, also, searching in Google Argentina isn't helpful at all, all it gives me are links to a ebay-like web page (MercadoLibre).
will download several versions of awdflash and do some testing to se if i can dump it, later i will see if i can flash another newer. (have to find one aswell)
Reply 6 of 15, by dionb
Use Uniflash 1.40
http://www.rainbow-software.org/download/uf140.zip
Just run the program (in DOS, preferably with no memory managers loaded) and you get the option to save the current firmware. Choose a filename (tip: use the BIOS version string from the POST screen) and done.
Good question, expect to need a lot of digging. Worth noting: the 810LMR is the same board as the ECS K7SEM. So maybe you would have more luck there.
Modding BIOS files is not an activity for beginners, so basic skills like dumping & flashing BIOS files are assumed known.
the cards tested are: […]
What about the chipset drivers? SiS AGP GART in particular. Did you install them on every OS you tried before installing the card drivers? If not, try that first.
Reply 7 of 15, by weldum
Agp gart was installed in both XP and 98SE
what would happen if i flash the latest bios from ECS on this board?
I've tried with setfsb to modify the fsb but the pll is not supported
Reply 8 of 15, by dionb
Ok, then that's not the issue.
Still interesting that you have most problems with the more advanced AGP cards though... maybe worth looking at the AGP settings in BIOS.
Probably just a working system with different name and BIOS (iirc the PC Chips version is Award, ECS uses AMI). But it could end up partly or wholly not working. That's why the backup of your present BIOS is so important.
Do you have another board with the same 32p BIOS EEPROM socket? Worst case you couldul use that to hot-flash the old BIOS back.
Which version?
Reply 9 of 15, by weldum
It doesn't have any agp option
I think i have another bios chip, have to see...
I've used the last setfsb version released
Reply 10 of 15, by lazibayer
IIRC M810LR's ECS equivalent is K7SEM. You may try the latter one's BIOS, which comes with FSB adjustments.
Reply 11 of 15, by weldum
sadly, the board doesn't power up more, and i didn't even flashed the bios
it's like sudden death
anyway thanks a lot to all of you, i like vogons a lot
respects
Reply 12 of 15, by PCBONEZ
weldum wrote:
sadly, the board doesn't power up more, and i didn't even flashed the bios it's like sudden death anyway thanks a lot to all of […]
respects
That sounds like a capacitor or capacitors gave out. Could be mobo or PSU caps.
Bad caps (going but not gone yet) would also explain the unstable behavior.
How are you with a soldering iron?
Reply 13 of 15, by weldum
PCBONEZ wrote:
That sounds like a capacitor or capacitors gave out. Could be mobo or PSU caps. Bad caps (going but not gone yet) would also exp […]
respects
Wrong
sadly, this board (with some others from my collection) are broken, in some places the traces are really broken, is too much to fix, and don't have the right tools or time to fix.
that's what i get for being lazy and putting all the motherboards in one pile.
Reply 14 of 15, by PCBONEZ
weldum wrote:
Wrong […]
respects
Wrong
I used to buy-repair-sell as well as offer repair services for motherboards.
At times I had as many as 300 motherboards here at the same time.
I would buy pizza boxes in bulk (50-100 a pack) and those worked very well to keep mobos from breaking each other.
They also stack nicely on shelves.
The 12" x 12" work for full ATX if you cut 1/3 of the front fold-in flap off to clear the PCB.
10" x 10" works for most smaller boards.
8" x 8" works for bulk RAM and many add-in cards.
I put RAM in ESD HDD clamshells when ESD bags aren't convenient for the quantity.
Reply 15 of 15, by weldum
Nice idea, I'll keep in mind that
I had about half of my collection in their original boxes, but the other half was jus stacked up in a corner or my workroom, most of these broke, so i have only the ones that have a box
I will sell in my country the broken boards as a scrap parts
