First post, by Smack2k
- Oldbie
On one of my PC Cases, the plastic cover piece that goes over the actual power button looks to have broken. The physical plastic piece is fine, but when I try to push it in, it goes in and stays in, doesnt come back like it should. This is causing it to also not make contact with the actual power button unless you have it at a certain angle and push on it.
Is there a way I can fix the button so it springs in and out like it used to and hopefully hits the power button each time its pressed? Right now, I had to pull the plastic cover piece out and just hit the actual black power button each time....looks bad!
