First post, by Kreshna Aryaguna Nurzaman
Well, I did.
It was quite long ago, when I was still using Voodoo5 5500 on Asus A7V333. I swear I didn't mess around with spread spectrum setting in the BIOS at that time, since I didn't even know about such thing back then. Recently I read the mobo manual again, and no, no spread spectrum setting found in the manual. Then I moved the Voodoo5 5500 to a 440BX mobo --a DTK PRM-0800I, to be exact; a Pentium II mobo. Unfortunately I haven't got the chance to actually use the 5500 for 3dfx games, since the system was primarily to test DOS GLide games on a Voodoo2 which was also part of the system. The Voodoo5 was nothing more than a glorified VESA card, alas. Then the mobo stopped working, thus, my interest to move to Super Socket 7. But I haven't actually got the time to do anything about it either.
Then I suddenly remember this spread spectrum thread, and many others.
Problem is; most 440BX motherboards --and probaly many, many older motherboards as well-- don't have the option to turn off spread spectrum. Not in BIOS, not through jumper either. The only 440Bx mobo I knew capable to disable spread spectrum is Intel's own, using jumper J14.
So, anyone else able to run Voodoo5 5500 without disabling spread spectrum?
Kreshna Aryaguna Nurzaman.
Reply 1 of 1, by weldum
there were boards in wich can be disabled spread spectrum, that had the 440bx chipset
two of the bunch of cards i had had this option in bios: BCM QS440BX and AOpen AX6BC
all the others were crippled in performance, in the chipset, in the bios, or in the processor compatibility
DT: R7-5800X3D/R5-3600/R3-1200/P-G5400/FX-6100/i3-3225/P-8400/D-900/K6-2_550
LT: C-N2840/A64-TK57/N2600/N455/N270/C-ULV353/PM-1.7/P4-2.6/P133
TC: Esther-1000/Esther-400/Vortex86-366
Others: Drean C64c/Czerweny Spectrum 48k/Talent MSX DPC200/M512K/MP475
