First post, by amijim
Hello there,i am facing some slowdowns with my rev 1,04 using a k6-3+ 450 oc to 600mhz.It is more like a stuttering i would say.I am using winME with 768mb ram and an ati rage fury maxx.I have not complete testing but i will try this mod and report back but has there been a report of problematic behaviour before with a rev 1,04 and a k6-3+?
Iwill ZmaxDP
Arima4way
Tyan s2885
Iwill MPX2
Gigabyte GA-7DPXDW+
Compaq SP700
Compaq ml350
Reply 1 of 4, by F2bnp
That's probably the Fury MAXX causing those stutters.
Reply 2 of 4, by fitzpatr
This should be in a new, or at least different, thread.
MODS: RECOMMEND THAT THIS BE SPLIT
Now that that's out of the way...
768MB is, in all likelihood, overkill. The Asus P5A rev 1.04 should be fully compatible with the K6-III+ CPU, so there should be no requirement to mod it. See the quote below for more details. The Rage Fury MAXX does suffer from some issues due to the way in which the dual GPUs are implemented. When are you experiencing the stuttering?
Quoted from: K6-2/3+ Success on Asus P5A 1.06 - simple mod
FesterBlatz wrote:
The title says it all! Following a vague post on k6plus.com regarding a simple modification to correct the "slowness" issue when paring K6-2/3 "plus" variants with Aladdin V rev G Northbridge equipped P5As (rev 1.05 & 1.06), I went ahead and tried this on my P5A rev 1.06 -- so far the results look promising!
MT-32 Old, CM-32L, CM-500, SC-55mkII, SC-88Pro, SC-D70, FB-01, MU2000EX
K6-III+/450/GA-5AX/G400 Max/Voodoo2 SLI/CT1750/MPU-401AT/Audigy 2ZS
486 Build
Reply 3 of 4, by Stiletto
Split thread.
do the Fandango!" - Queen
Stiletto
Reply 4 of 4, by amijim
I get stuttering both with winme and lubuntu while hovering the mouse around desktop.During the weekend i will make a fresh installation of win me win 98se and lubuntu 586 on a new scsi hd and report back witha video.
Iwill ZmaxDP
Arima4way
Tyan s2885
Iwill MPX2
Gigabyte GA-7DPXDW+
Compaq SP700
Compaq ml350
