First post, by Shernand
Shernand
Offline
- Newbie
Hi,
I desesperately need your help to repair my mt-32 sound module, i "burned" the R and L audio outputs, i took it to a technichian friend and he says that due that almost everything was burnt inside (in the R and L output areas). The output part of the board is completely burnt, to rebuild it i need a VERY close photo of the output part of the circuit (upper side).
Thanks in advance
-- Shernand
