First post, by Vipersan
Having arrived at the conclusion that theSCV6 Tomato sound card is totally unsuitable for use in my Toshiba T3200SX ..which I would like to use with DOS6.2 only.
I've aquired a Vibra Creative SB16 CT2800 16 bit ISA card.
I have no idea if it is even working ...
A friend donated it untested.
Sadly he didn't have any floppies ..so I am driverless and clueless as to what I need and how to go about getting it installed.
I guess I need a setup floppy ...drivers and diagnostics/tests and samples.
Could some kind soul ..help me with this ..?
As I said ..it isn't even clear as to functionality ..so first order of business is to get it installed and tested.
The software ideally must be floppy based ..as this is the only IO on the T3200SX
rgds
VS
