First post, by Tiido
- l33t
I have a Chaintech 5VGM mobo with a very strange issue, when L2 cache is enabled it will freeze in things like Speedsys, windows boot and memtest (always in a certain %) regardless of CPU type and speed, RAM timings also make no difference, nor use of any other RAM sticks. I could play Duke3D without crashes and all other DOS games I tried. With cache disabled everything works perfectly also (but performance is really poor). I had replaced all the important capacitors at that point also.
So I though I'll just replace the cache chips... 15 mins later it is done and the problem still presists. OK, next step is TAG RAM... 15 mins later, chip is replaced and still no improvement...
Then I decided I will replace the northbridge, I have another P1 board with same sort of chipset but lacking second voltage regulator so no MMX CPUs support. I do the northbridges swap and the problem still presists, the other board works perfectly as it did with its own chip. Then I swapped out the Data Path chips, still same result, problem mobo still has the problem and donor is still working perfectly...
So there's only one last major chip left, the southbridge. Fast forward 30 mins and these chips got swapped too... and the problem still presists !
I don't see any excess ripple on the power rails, voltage regulators are all ok too, I even opened the CPU socket to see if there's any broken pins there but that one checked out too... So it seems that the problem is most probably mechanical, a bad via or something else along the lines...
Here's some photos of the process :
http://www.tmeeco.eu/BitShit/PCschit/MoboRepair0.jpg
http://www.tmeeco.eu/BitShit/PCschit/MoboRepair1.jpg
http://www.tmeeco.eu/BitShit/PCschit/MoboRepair2.jpg
http://www.tmeeco.eu/BitShit/PCschit/MoboRepair3.jpg
http://www.tmeeco.eu/BitShit/PCschit/MoboRepair4.jpg
http://www.tmeeco.eu/BitShit/PCschit/MoboRepair5.jpg
http://www.tmeeco.eu/BitShit/PCschit/MoboRepair6.jpg
