First post, by Vipersan
So ..I wanted to restore an IBM Thinkpad 600X back to factory image with win98.
Actually this proved to be a massive problem for me ..
Sure I could use Fdisk ..format ..and win98SE .
..but I actually wanted it Factory restored so having the 'look' that IBM intended.
A Vogon member Thermal wrong very kindly imaged the original IBM restore ISOs for me and sent me copies.
Cheers buddy.
These arrived today ..and I finally was able to restore the laptop.
BUT
...the restored image creates win98 not win98se...and to use a larger drive I really wanted FAT32 ...
The restored image automatically partitions before installation in FAT.
Somewhere in the deepest recesses of my mind I seem to remember that during the transition phase when larger drives became readily available and everone moved away from FAT to FAT32 there was a util that did this conersion without data loss ..?
which might be an option I can use..
create the FAT image ..and convert to FAT32 (losslessly ..then expand the partition.
does anyone remember doing this ?
I Guess I could just unhide everything and transfer the data directly to a FAT32 partitioned drive..but then ..would this even work ?
chances are win98 not 98se doesn't actually support FAT32.
anyone ?
rgds
VS
