First post, by Raymo99
Hi folks,
Have an error in the status box of DosBox
Error =BIOS INT14: Unhandled Call AH=81 DX=0
I'm running Dosbox in Win 10 64 bit
Is 64 bit causing this error?
Trying to run an old kenwood radio dos package called KPG67D, it's for programming Kenwood walkie talkies.
I'm using this line in the cong file: serial1=directserial realport:com2
my serial device is set up as Com2
so all should be good, except for the error in the status window,
really would appreciate any suggestions, this is my third evening trying to solve this.
Thanks
Ray
Reply 1 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
did you forget to load one of the drivers (of the program you are trying to run) ?
http://www.delorie.com/djgpp/doc/rbinter/ix/14/81.html
all those calls refer to driver packages. not something obvious that dosbox should have
Water flows down the stream
Reply 2 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
thinking of it a bit more.
It can be that the radio package is just doing a detection run for all kinds of possible drivers. So it might be fine to ignore it, if it works.
Reply 3 of 4, by Raymo99
Thanks,
I actually found a solution which didn't require the use of DosBox. There is a windows version of Kenwood software.
Cheers
Ray
Reply 4 of 4, by johnkinesis
Raymo99 wrote:
Thanks, I actually found a solution which didn't require the use of DosBox. There is a windows version of Kenwood software. […]
Thanks,
Cheers
Ray
hello man, do you have a link how to download that windows version of kenwood software? i have the same problem, i can't program repeater. TK-768G Kenwood. Thanks for the response.
