First post, by GabrielKnight123
Hi all, I have a 486DX2 66 Pc running DDO Ver 9.57 for Dos 6.21 running great but when I unplug my Dvd drive and have just the HDD connected the HDD does not get detected at boot but in the Bios it still has the same settings that DDO set on user 32. I found this when I was trying to swap the IDE Dvd drive for a Scsi one that connects to my PAS16 sound card so it doesnt get detected when the Ide drive isnt connected and when I connect a Scsi one is this some sort of setting that gets written when the DDO software is installed that looks for a single device setup at the time of install that cant be changed?
Reply 1 of 4, by Jo22
Hmm. Strange. That's one of these reasons I tend to stay away from DDOs, though.
I'd recommend upgrading the BIOS to the latest version (in order to get support for larger drives) or to use XTIDE Universal BIOS.
XTIDE Universal BIOS can be easily installed on a network card (whch, however, also requires an IRQ).
If you wish, a friendly fellow vogons member (or I) will program an EPROM with XTIDE for you.
PS: Perhaps it's a hardware issue, too. Make sure the HDD is set to master/primary or auto-select.
Some drives have issues if they are alone on the cable, but configured for slave/secondary.
Reply 2 of 4, by RJDog
This was exactly what my first thought was. I don't think it has anything to do with the DDO...
Reply 3 of 4, by GabrielKnight123
Im using a 20 GB drive and I have the drive set as master using a 40 wire cable, I ended up replacing the DVD drive because it was faulty mainly read errors and since I need a Dvd drive and a new one is in the Pc my problem for now if fixed but I would be interested to know why this was happening.
Reply 4 of 4, by tayyare
Some (generally older) drives has another jumper setting as "single" besides master and slave. I don't think a 20GB drive has this feature(?), but I'm mentioning it just in case.
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
