First post, by GabrielKnight123
Hi all, I found a heatsink and fan here at home that will do the job quite well to go with my AM5x86-P75 CPU but I need a thermal pad to stick it to eachother, would it be best to use a 1mm pad or a 0.5mm pad I dont know but wouldnt the 0.5mm be better for heat transfers because of the thickness?
I found these:
https://www.pccasegear.com/products/29189/ek- … hermal-pad-1mm/
https://www.pccasegear.com/products/29192/ek- … al-pad-b-0-5mm/
Or is this the wrong type of pad?
