First post, by Vikingo
Hello!
I do not remember if this is the normal behavior of the plug and play cards. Every time I restart the computer my Sound Blaster has an IRQ, DMA or Address totally different from the last boot.
This means that I have to reconfigure the games every time I execute them.
Is there a way to hard set these parameters?
Thanks!
Follow me on twitter @cristian. 🤣
Reply 1 of 4, by badmojo
That doesn’t sound right! What OS?
Reply 2 of 4, by Vikingo
Using DOS 6.22. It works perfect but have to reconfigure games every time if setting change.
Reply 3 of 4, by jesolo
Try running CTCU again and verify that the default resources have been allocated to your sound card (Base port 220h, DMA 1 & 5, IRQ 5, MPU-401 Port 330h, & EMU synthesis port E620).
Reply 4 of 4, by matze79
Maybe if it helps, you can edit the cfg files and write protect them 😁
