First post, by PcBytes
So here I am, with an all-new fleet of machines. Some are going to be upcoming, as soon as I get the parts I'll post pictures of them or update you if they are cancelled or anything.
I'm going to list them in order, from "new" to old.
Main machine:
Xeon X5450 OC'd to 3.5
DFI Lanparty DK P43-T2RS
RPC 500W (modified)
8GB DDR2-800 RAM (3x Corsair 2GB & 1x2GB ADATA)
JNC 4JA case with thermal sensors
R7 240 2GB from Sapphire
AVerMedia AVerTV M733A
Sony-Optiarc AD-5200A DVD-RW
1TB Samsung HD103SI
Card Reader
Win7 X64
"K8-III+"
AMD Sempron 2800+
ASRock K8Upgrade-NF3
L&C LC-B350ATX
512MB RAM
some random ricer case
Palit Geforce FX5500 256MB 8x
HL-DT-ST GSA-4167B DVD-RW
80GB Hitachi IDE HDD
Windows XP SP3
"KayEight"
AMD Athlon 64 3000+ Skt939
Gigabyte GA-K8NS-939
FSP/Sparkle FSP300-60EP(2)
2GB RAM
K-Mex CX3356 case
ASUS/ATi Radeon HD3450 512MB AGP8x
HL-DT-ST GSA-H10N DVD-RW
80GB WDC SATA HDD
Windows XP SP3
"Blue Falcon"
Pentium 4 2.4GHz
ASRock P4VM890
Delta DPS-300PB-2A
512MB RAM
Delux MT375 case
Manli/nVidia Geforce 7300LE 256MB PCI-E
HL-DT-ST DVD-ROM/CDRW
2x 80GB IDE WDC
Windows XP SP3 and 7 x86 dualboot
"XP"
AMD Athlon XP 2500+ OC'd to 3200+
ASUS A7N8X-E Deluxe
Allied AL-A400ATX 120mm 400W
512MB RAM
JNC RJA-52 case
Palit Radeon 9550 128MB AGP8x
Hitachi-LG DVD-ROM/CDRW and TEAC CD-540E
2x 80GB IDE WDC
K-World BT878 PCI TV Tuner
Windows XP SP3
"Turbo7"
AMD Athlon 750MHz
Epox EP-7KXA
Torrent Computers LC-B400ATX 400W (modified)
128MB RAM
Frontier black ATX case
HL-DT-ST GSA-H58N DVD-RW
15GB Quantum Fireball lct15 QML1500LC-A
nVidia Geforce MX440 AGP8x 64MB
Realtek RTL8139C NIC
Windows 98 SE
"Code 002"
Pentium 3 850MHz Coppermine
LuckyStar 6VA694+ (VIA 694X)
JNC LC-B350ATX 350W (modified)
256MB RAM
JNC FQ-70 case
Hitachi-LG GCE-8481B
10GB Seagate ST310211A - Windows 98 SE
40GB WD400BB - Windows 2000 Server
40GB Maxtor 6E040L0 - games drive
Sound Blaster 16 "SB16 VALUE" CT2770
"Code 001" (upcoming)
AMD K6-2 500MHz
LuckyStar 5MVP3 (VIA MVP3)
Frontier LC-B400ATX (modified and recapped)
256MB RAM
no case until I find a new one (or will possibly reuse the one that houses the EP-7KXA)
10GB Seagate ST310211A - 98SE Plus!
3dfx Voodoo 3 2000
VIA VT6202 PCI
Intel SB82558B PCI NIC (Compaq OEM)
"United States of Smash" (upcoming)
AMD Duron 1GHz
ECS K7VZA rev3 w/ Chaintech 7AJA2 BIOS (it works and runs MILES better than the original K7VZA bios)
Deer DR-A300ATX (modified)
384MB RAM
again no case
40GB WD400 IDE - Windows ME
MX440 AGP8x 64 MB (I have lots of them)
Realtek RTL8139D NIC
"Grape" (not sure, will post it if I get it)
Pentium III 500MHz Katmai
MSI MS-6163VA MB
192MB RAM
Mitsumi CRMC-FX4820T
8GB WDC Protege
Terratec/ESS TTSOLO PCI soundcard
ATI RAGE Pro 128 AGP (will probably replace it with a Geforce 2 MX400 64MB)
And this is the "mighty" fleet. Will post pictures tomorrow of those that are with me (some are stored away but accessible when I need them) as well as the parts I currently have and the ones I will get (mainly the K6-2) in detail. Feel free to ask me anything and also leave a suggestion if you think I should replace some parts in any of them.
I also have a Celeron 500MHz (Mendocino core) but no mobo to put it in 🙁 Hope I find a 440BX S370 mobo to put it in.
Also a virtual cookie to anyone who recognizes the names of the Coppermine, K6-2 and Duron machines.
hint: recent anime shows, 2016 and 2018 respectively
Reply 1 of 12, by PcBytes
Just converted a CuMine only mobo (the 6VA694+) into a Tualatin compatible board!
I used the Soyo SY-7VBA133U BIOS - it works just fine, and now the board POSTs happily with a Tualatin P3 at 1.1GHz.
Just a heads up - if you have a VIA 694X motherboard and a Tualatin, don't skip the 694X! I might be able to help you convert it to a Tualatin compatible board by just flashing a BIOS meant for 694T! They're the same chipset, with the only difference being the 694T supports Tualatin while 694X does not, otherwise they're 99% the same and compatible between each other (as long as the BIOS is coded to support Tualatins, that is)
Reply 2 of 12, by kixs
Wasn't there also a bit different socket? At least when people did the mods, the pins had to be rewired. Most probably for proper voltage as Tualatins need only 1.5V.
Visit my AmiBay items for sale (updated: 2025-10-29). I also take requests 😉
Reply 3 of 12, by PcBytes
Great news!!!
The K6-2 is going to arrive here on Monday!
In the meantime, what would you suggest I should do to it once I get it? I already planned to install 98SE w/ Plus, but other than that, what would your ideal 98SE drive would include? I was thinking of 98lite (for some performance boost) and a Unofficial Service Pack 3.
Reply 4 of 12, by oeuvre
skip the SP3 honestly, it has caused me grief in the past
Reply 5 of 12, by PcBytes
Okay, noted.
What should I look into then? Any hotfixes I should be looking into specifically?
Reply 6 of 12, by oeuvre
Directx june 2006 redistributable
IE 6.0 SP1
TweakUI 1.33
InstMsiA.exe
MDAC_TYP.exe
unicows.exe
vbrun60sp6.exe
Windows Media Player 9
WMI9X.exe
Reply 7 of 12, by PcBytes
oeuvre wrote:
Directx june 2006 redistributable IE 6.0 SP1 TweakUI 1.33 InstMsiA.exe MDAC_TYP.exe unicows.exe vbrun60sp6.exe Windows Media Pla […]
IE 6.0 SP1
TweakUI 1.33
InstMsiA.exe
MDAC_TYP.exe
unicows.exe
vbrun60sp6.exe
WMI9X.exe
Okay, although wouldn't IE6 not work? I plan on using 98lite to slim the main install down.
Reply 8 of 12, by canthearu
I found that Unofficial SP3 works fine after you install IE6.0 on Win 98SE
if you don't install IE6.0, explorer will no longer work.
Reply 9 of 12, by PcBytes
98lite replaces explorer with the 95 version.
Reply 10 of 12, by PcBytes
...aaand the K6-2 500 arrived!
One dented Tayeh cap (only a bit) but otherwise it POSTs fine and works as it should. Didn't get a successful boot into 98 but I suspect that being a conflict as the HDD came from the 7KXA machine.
I discarded the K7VZA machine for a KT400-based configuration with the Gigabyte GA-7VAX (KT400, DualBIOS). The only thing left to do on it now is to get it to run Athlon XPs. For some weird reason any 333 Athlon will shut down a few seconds after powering on. Semprons and Durons POST fine though.
Reply 11 of 12, by PcBytes
Some pics of the K6-2 machine.
Reply 12 of 12, by PcBytes
Updated the soundcard in the K6 - now it sports a Yamaha OPL3-SAX ISA Soundcard (from Labway).
