First post, by appiah4
- l33t++
I am currently repairing a CT3980 AWE32 with missing and broken components. One of the capacitors missing on the card is C121, right below the regulator. There are three types of caps on the card that are a likely fit there: 50V 4.7uF, 50V 1uF and16V 10uF ones. I soldered on a 63V 4.7uF cap there before I realized the other kinds were actually on the card, so I now need to figure out whether I did something really wrong and remove it. If someone with the card on hand can chime in and post the specs of the cap marked below I would be very grateful:
