First post, by aries-mu
Hi guys,
so: branded 486 PC, Compaq Prolinea 4/66. It has a motherboard-integrated Tseng ET4000 W32i SVGA, 1 MB, 1024 x 768 @ 256 colors.
When the tech specs say that the SVGA is "local bus"....
Can you assume it is faster than the ISA bus? And, if so, what the bandwidth of this "local bus" would be?
Good luck with that!
Thanks.
They said therefore to him: Who are you?
Jesus said to them: The beginning, who also speak unto you
Computers should be fun inside not outside! 😉 (by Joakim)
