First post, by vanfanel
- Newbie
Hi all,
I have been using a customized version of dosbox on both my Pi3 and X86_64 GNU/Linux systems. It's an SDL2 version (thanks to NY00123's work!) that I manually patch to accept a custom screen refresh rate.
This custom refresh rate is needed so fine-scrolling games like SuperFrog, Pinball Dreams, etc... exhibit the same PERFECTLY smooth scroll they do on a real machine.
This is my patch, it's very simple:
diff -rupN dosboxA/include/vga.h dosboxB/include/vga.h--- dosboxA/include/vga.h 2018-07-22 12:48:06.811331826 +0200+++ dosboxB/include/vga.h 2018-07-22 13:03:33.170575180 +0200@@ -407,6 +407,7 @@ typedef struct {VGA_Changes changes;#endifVGA_LFB lfb;+ double refreshRate;} VGA_Type;diff -rupN dosboxA/src/gui/sdlmain.cpp dosboxB/src/gui/sdlmain.cpp--- dosboxA/src/gui/sdlmain.cpp 2018-07-22 12:48:29.932580021 +0200+++ dosboxB/src/gui/sdlmain.cpp 2018-07-22 13:02:40.413114180 +0200@@ -1881,6 +1881,8 @@ static void GUI_StartUp(Section * sec) {if (sdl.desktop.full.display_res) {GFX_ObtainDisplayDimensions();}+ vga.refreshRate=atof(section->Get_string("refresh"));+ LOG_MSG("Physical refresh rate %f \n", vga.refreshRate);#else // !SDL_VERSION_ATLEAST(2,0,0)@@ -2662,6 +2664,9 @@ void Config_Add_SDL() {Pbool->Set_help("Sync to Vblank IF supported by the output device and renderer.\n""It can reduce screen flickering, but it can also result in a slow DOSBox.");+ Pstring = sdl_sec->Add_string("refresh",Property::Changeable::Always,"60.0000");+ Pstring->Set_help("Screen refresh rate.");+#ifndef __ANDROID__Pstring = sdl_sec->Add_string("fullresolution",Property::Changeable::Always,"0x0");Pstring->Set_help("What resolution to use for fullscreen: original, desktop or a fixed size (e.g. 1024x768).\n"diff -rupN dosboxA/src/hardware/vga_draw.cpp dosboxB/src/hardware/vga_draw.cpp--- dosboxA/src/hardware/vga_draw.cpp 2018-07-22 12:48:06.807330793 +0200+++ dosboxB/src/hardware/vga_draw.cpp 2018-07-22 13:04:49.909575548 +0200@@ -1200,7 +1200,9 @@ void VGA_SetupDrawing(Bitu /*val*/) {if (!vtotal) return;// The screen refresh frequency- fps=(double)clock/(vtotal*htotal);+ // fps=(double)clock/(vtotal*htotal);+ fps=vga.refreshRate;+ clock=((double)(vtotal*htotal))*fps;// Horizontal total (that's how long a line takes with whistles and bells)vga.draw.delay.htotal = htotal*1000.0/clock; //in milliseconds// Start and End of horizontal blanking
The relevant part is only this:
fps=vga.refreshRate;clock=((double)(vtotal*htotal))*fps;
Thing is, it was working fine, but with recent DOSBOX SVN code I am getting sound desynchronized once in a while, which is annoying. So, any ideas on what else should I change so the GUS/SB emulation will produce as many samples per second as needed depending on the custom screen refresh rate? (I suspect that's the problem)
