First post, by mrmin123
Hi... I'm trying to run TIE Fighter Collector's CDROM (the one with TIE.EXE, not TIE95.EXE) on my XP box... 1.4AMD, Geforce3Ti300, 512MB DDR RAM, SoundBlaster Live! Value (but with a 3rd party audio driver... the kX ones). I saw lots of people on this forum try to answer the question, but none of them seems to work for me (or I get a totally different problem...), so I'll give it a go ... again.
TIE is installed in default C: directory, Maximum install
I guess the problem is (as usual), the sound... I've tried a bunch of stuff... first I set it up so it was Custom/Advanced setup... General MIDI for music, auto detect for sound (SB16 I think?). 'Test' for music would crash install.exe, while sound works fine. If i try to play with this setup, the came goes to a blank screen and dies.
So then I try disabling music (none) and running the game; it runs fine, sound, joystick... except, well, music!
Then I let install.exe auto-detect the sound card, and it finds something.. I try running the game again, and bam, i get the same blackscreen again.
Ok... maybe that was only 3 alternatives (all run with VDMSound)... but I'm still running out of ideas.... So, anyone have an idea of waht to do?
Thanks!
Reply 2 of 2, by _sir_maniac
You might be running into a problem with the VESA modes that TIE Fighter uses. On the following page, you will find a utility that fixes a bug in using VESA modes in a NT/2K/XP dos box.
http://advsys.net/ken/build.htm
it's called NOLFB.ZIP, and includes instrucions to it's use at that site.
As an alternative, there is a patch to make TIE95 run under WinXP(if the collectors edition included the TIE95 version):
http://www.lucasfiles.com/index.php?s=c0c7b04 … 2aa3b81b1930b95
Good luck.
