First post, by todd
Hi there is an issue.
I installed this for PSOBB to see if it worked better or the same as the directx8 to directx9 wrappers from reshade.
There is no issue with the reshade wrapper that I know of besides slow frame rate at very high res in a few spots which might be hardware limit.
PSOBB works great with the reshade one enabling me to play at 4K res, 2xEQ AA, 16xAF etc.
The main problem these wrappers fix for PSOBB as a directx8 game is the fact nVidia Optimus and switchable graphics on AMD no longer support directx8 so the games cannot be detected properly and ran on discrete graphics cards. None switchable graphics systems have no real issue just running directly. There may be performance boosts or other fixes by using a wrapper tho, have not tested.
The issue with dgVoodoo 2 is when starting PSOBB in classic fullscreen mode at 1080p the screen is black with just the mouse cursor. Sometimes the game launching flips out and somehow ends up in a tiny window which the game renders in fine but is too small- odd.
One thing I should mention if it has anything to do with this is I do run dgVoodoo 2 PSOBB from steam as I have a steam controller. The steam controller does not work with any game unless launched from steam or otherwise with steam open. It does add a graphical feature to PSOBB such as a virtual keyboard etc.
Anyway wonder what the issue is. Any idea?
Todd Giffen
Reply 1 of 33, by Dege
Hi,
Does it work for you in windowed mode?
It's a bit weird, I just tried PSOBB (altough not the Steam version) in fullscreen 2560x1440 and it worked for me fine.
Reply 2 of 33, by todd
The attachment pso131780282053574777.jpg is no longer available
-edit-
Reply 3 of 33, by todd
This is odd. Fullscreen works now but it has the same missing text starting at the start screen as the above screen shot. All menu items, chat text, user names etc are like that.
This is very strange as I changed nothing on my PC but switched to reshade dx8 to dx9, changed some AMD control panel settings to optimize quality and performance.
Anyway now the game starts fine all modes. It is just the text is corrupt.
Reply 4 of 33, by todd
Was able to do more testing.
Window mode works.
But for classic fullscreen mode, it might only work in the monitors native resolution.
So my monitor is 4K. 4K res starts but text is corrupt. This is one of the other settings I changed is setting the game to 4K instead of 1080p.
If I set res to 1080p or anything else, something will cause the app to freeze at the start.
There could be an issue with the windows popup that asks if you want to fix your resolution or blurry apps.
The other thing to know about this game is it locks up if the game ever loses full screen focus. So if the dgVoodoo 2 wrapper or windows 10 is somehow sending a signal it should not that fullscreen has been interrupted, it will freeze.
I am wondering if the windows 10 popup that asks if your app is blurry when in fullscreen without native resolution is having an effect on dgVoodoo 2 and the PSOBB activating the games built in freeze function?
Dont know why PSO and PSOBB freeze but in the first version of the game there was no window mode. Only fullscreen and if you tried to leave fullscreen or accidentally hit the windows key or anything, you would end up freezing or crashing the game.
The way this looks I think - if I am onto the right thing - is PSOBB with the dgVoodoo 2 wrapper simple displays a black screen at start up, sometimes with a mouse cursor, or sometimes displays the first loading frame before freezing. This difference between black screen or first frame might correspond to the windows 10 popup appearing about not being in native resolution- which takes different time each load depending on factors.
Also I can confirm in regular PSOBB, if you even so much as click cancel on that windows 10 popup the game will freeze immediately. This is difference between dgVoodoo 2 PSOBB and regular PSOBB: regular PSOBB allows the popup from windows 10 without freezing but will freeze if you click the popup. dgVoodoo 2 PSOBB freezes just if the popup appears or tries to.
Also I can confirm that with dgVoodoo 2 upon starting psobb with any resolution, the game randomly starts in a window mode instead of fullscreen, but the window is so small you can barely see the game, rather than starting up in classic fullscreen as intended.
And the text all throughout the game is replaced with white or gold boxes even if you do get it started.
Testing using ephinea version of app.
Reply 5 of 33, by ZellSF
Try running it without ReShade and Steam overlay? You're adding complicating variables before you have solved the basic problem which is stupid.
Also disable DPI scaling in compatibility settings for the program if you think that's the issue?
Reply 6 of 33, by todd
I already did. I dont have steam or reshade enabled during my tests.
I only had steam on the first time I noticed it.
Launching the game directly has the same issue.
I never had reshade installed. I only use the reshade directx8 to directx8 wrapper, which when dgVoodoo 2 is installed replaces reshades dll.
No DPI scaling is not the issue. WINDOWS 10 unlike previous versions of windows always warns the user when they run the desktop or a game in non native resolutions. This is where dgVoodoo 2 is having a fuck up causing a conflict with the warning popup which does not happen when dgVoodoo 2 is not in use.
Reply 7 of 33, by ZellSF
Does it show that warning popup when you've explicitly chosen a DPI scaling mode in compatibility options?
Reply 8 of 33, by todd
The app is already 100% scaled properly. Fully DPI compliant game.
Set your desktop resolution to lower than the native and windows will show the popup there too.
Windows 10 gives the warning whenever the screen is not running at native.
Reply 9 of 33, by ZellSF
Windows 10 (1803 and lower at least) do not give any sort of warning when changing resolutions to lower than native. It only gives warning when changing DPI settings while still logged inn, which might correlate with a resolution change, but the cause is still DPI settings. So if a game is triggering that notification, manually setting a DPI scaling mode might fix it. There's also a "No and don't show again" in the notification.
I don't believe the notification is the problem, but getting rid of it and ruling it out shouldn't be difficult.
Reply 10 of 33, by todd
The option for DPI scaling is already set correctly.
This game handles it's own DPI so it is set to application.
I happen to be in the Windows 10 insider club, I am on a mega advanced build.
This popup box only appears if running the game in non native resolution. There is probably also a box for DPI settings too.
The box is definitely the problem. Switching to native resolution eliminates the box, and the game runs.
Switching to non native resolution activates the box causing dgVoodoo 2 PSOBB to freeze.
If you cannot get the little popup to appear on your system you may have already disabled it or are not running in sub native resolution.
Reply 11 of 33, by ZellSF
As I said, I'm running 1803, the stable build of Windows. That popup does not exist there. If it isn't third party software (can you make a screenshot of the box?) then it's something new specifically to insider builds.
Reply 12 of 33, by todd
Have no idea if the popup is causing it but that popup is a nasty biatch possibly. dgVoodoo 2 just doesn't work on my config at any resolution.
I reinstalled dgVoodoo 2 and for 4K resolution, and qHD, the game creates a mini black box in the corner then crashes.
Anyway I have confirmed dgVoodoo 2 is just a big piece of turd.
Both ENB and ReShade's DirectX8 to DirectX9 wrappers work fine confirming the issue is dgVoodoo 2 not a third party wrapper.
PSOBB also works fine with all wrappers uninstalled except it runs on the intel graphics because it is a directx8 game.
Reply 13 of 33, by todd
here's a debug:
[\\DESKTOP-HKAVRA7]
00000001 0.00000000 [12744] RecursiveDirectoryCreate( C:\Users\wiseg\AppData\Local\CEF\User Data directory exists )
00000002 0.06427090 [13920] IPC server is in my process - could/should be using an in process pipe
00000003 0.08905010 [12744] [0812/183021.240:INFO:crash_reporting.cc(215)] Crash reporting enabled for process: browser
00000004 0.12172260 [13920] CApplicationManagerPopulateThread took 2 milliseconds to initialize (will have waited on CAppInfoCacheReadFromDiskThread)
00000005 0.13560820 [12744] [0812/183021.287:ERROR:gpu_process_transport_factory.cc(1029)] Lost UI shared context.
00000006 0.17118300 [13920] CAppInfoCacheReadFromDiskThread took 67 milliseconds to initialize
00000007 0.20236970 [13920] CHTTPRequestCache took 82 milliseconds to initialize
00000008 1.14467263 [13920] Local Device Found
00000009 1.14467263 [13920] type: 28de 1102
00000010 1.14467263 [13920] path: \\?\hid#vid_28de&pid_1102&mi_02#7&3abbaa23&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
00000011 1.14467263 [13920] serial_number: - 0
00000012 1.14476526 [13920] Manufacturer: Valve Software
00000013 1.14480126 [13920] Product: Valve
00000014 1.14489102 [13920] Release: 100
00000015 1.14491034 [13920] Interface: 2
00000016 1.14491034 [13920]
00000017 1.14505982 [13920] Controller uses V1 HID protocol
00000018 1.14515316 [13920] !! Steam controller device opened for index 0.
00000019 1.14553022 [13920] Steam Controller reserving XInput slot 0
00000020 1.20913744 [13920] Controller 0 connected, configuring it now...
00000021 1.65865076 [13920] Chip ID: 308002186794abaec6a43255401900f5
00000022 1.70768797 [13920] BYieldingQueryAccountsRegisteredToController
00000023 1.75030541 [13920] !! Controller 0 attributes:
00000024 1.75030541 [13920] Type: 2
00000025 1.75030541 [13920] ProductID: 4354
00000026 1.75030541 [13920] Serial: FC619203BC
00000027 1.75030541 [13920] Capabilities: 00013ff7
00000028 1.75030541 [13920] Firmware Version: 0
00000029 1.75030541 [13920] Firmware Build Time: 1527718333 (Wed, 30 May 2018 22:12:13 GMT)
00000030 1.75030541 [13920] Bootloader Build Time: 1439863405 (Tue, 18 Aug 2015 02:03:25 GMT)
00000031 1.75232923 [13920] Could not load local selection (), local override (C:\Program Files (x86)\Steam/controller_config/bigpicture.vdf), or user path (C:\Program Files (x86)\Steam/appcache//controller_configs/bigpicture.vdf), checking last resort path: C:\Program Files (x86)\Steam/controller_base/bigpicture.vdf
00000032 1.75973356 [13920] Loaded Config for Last Resort Path for App ID 413090: C:\Program Files (x86)\Steam/controller_base/bigpicture.vdf
00000033 1.76665723 [13920] Could not load local selection (), local override (C:\Program Files (x86)\Steam/controller_config/bigpicture.vdf), or user path (C:\Program Files (x86)\Steam/appcache//controller_configs/bigpicture.vdf), checking last resort path: C:\Program Files (x86)\Steam/controller_base/bigpicture.vdf
00000034 1.76963377 [13920] Loaded Config for Last Resort Path for App ID 413090: C:\Program Files (x86)\Steam/controller_base/bigpicture.vdf
00000035 1.77162480 [13920] Could not load local selection (), local override (C:\Program Files (x86)\Steam/controller_config/steamdesktop.vdf), or user path (C:\Program Files (x86)\Steam/appcache//controller_configs/steamdesktop.vdf), checking last resort path: C:\Program Files (x86)\Steam/controller_base/steamdesktop.vdf
00000036 1.77666402 [13920] Loaded Config for Last Resort Path for App ID 413080: C:\Program Files (x86)\Steam/controller_base/steamdesktop.vdf
00000037 1.77770436 [13920] Controller 0 mapping uses xinput : false
00000038 7.23012018 [12744] Found unsupported CDM version 1.4.9.1088, using last known good version 1.4.8.1008
00000039 11.78475761 [13920] Loaded Config for Local Selection Path for App ID 413080: C:\Program Files (x86)\Steam\steamapps\workshop\content\241100\650764041/controller_configuration.vdf
00000040 11.78512478 [13920] [413080]Non-Steam Controller Configs Enabled: 1
00000041 11.78746414 [13920] local (potentially out of sync) copy of roaming config loaded - 3693 bytes.
00000042 12.65886974 [13920] roaming config store loaded successfully - 3693 bytes.
00000043 12.65922165 [13920] migrating temporary roaming config store
00000044 12.86247921 [13672] [0812/183034.027:INFO:crash_reporting.cc(215)] Crash reporting enabled for process: gpu-process
00000045 12.88053322 [9448] [0812/183034.045:INFO:crash_reporting.cc(215)] Crash reporting enabled for process: renderer
00000046 13.36731625 [13920] Failed to init SteamVR because it isn't installed
00000047 13.44098568 [13920] ExecCommandLine: ""C:\Program Files (x86)\Steam\Steam.exe""
00000048 14.03650284 [13920] IPC server is in my process - could/should be using an in process pipe
00000049 14.04355717 [13920] System startup time: 14.17 seconds
00000050 14.04393482 [13920] !! Controller 0 attributes:
00000051 14.04393482 [13920] Type: 2
00000052 14.04393482 [13920] ProductID: 4354
00000053 14.04393482 [13920] Serial: FC619203BC
00000054 14.04393482 [13920] Capabilities: 00013ff7
00000055 14.04393482 [13920] Firmware Version: 0
00000056 14.04393482 [13920] Firmware Build Time: 1527718333 (Wed, 30 May 2018 22:12:13 GMT)
00000057 14.04393482 [13920] Bootloader Build Time: 1439863405 (Tue, 18 Aug 2015 02:03:25 GMT)
00000058 14.04466438 [13920] Fetching Config Sets 0
00000059 14.04479885 [13920] CClientJobFetchPersonalizationFileID
…Show last 195 lines
00000060	14.06091976	[13920] Blocking global navigation to: data:text/html,%3Cbody%3E%3C%2Fbody%3E
00000061 14.16389942 [13852] [0812/183035.329:INFO:crash_reporting.cc(215)] Crash reporting enabled for process: renderer
00000062 14.19801426 [9088] [0812/183035.363:INFO:crash_reporting.cc(215)] Crash reporting enabled for process: renderer
00000063 14.27734280 [13920] Set Account Config Sets 0 1 1
00000064 14.60515881 [13920] OnFocusWindowChanged to window type: k_nGameIDControllerConfigs_Desktop, AppID 413080
00000065 14.60775375 [13920] Loaded Config for Local Selection Path for App ID 413080: C:\Program Files (x86)\Steam\steamapps\workshop\content\241100\650764041/controller_configuration.vdf
00000066 14.60803318 [13920] [413080]Non-Steam Controller Configs Enabled: 1
00000067 14.60857487 [13920] OnFocusWindowChanged to window type: k_nGameIDControllerConfigs_Desktop, AppID 413080
00000068 14.61030674 [13920] Loaded Config for Local Selection Path for App ID 413080: C:\Program Files (x86)\Steam\steamapps\workshop\content\241100\650764041/controller_configuration.vdf
00000069 14.67731953 [13920] CAPIJobRequestUserStats - Server response failed 2
00000070 16.10744286 [13920] [413080-650764041]: Failed to start tracking playtime
00000071 16.27648354 [13920] [413080-650764041]: Failed to start tracking playtime
00000072 20.43580246 [13920] Loaded Config for Local Selection Path for App ID -2147483647: C:\Program Files (x86)\Steam\steamapps\workshop\content\241100\1459950924\957464882662497763_legacy.bin
00000073 20.43635941 [13920] [2147483649]Non-Steam Controller Configs Enabled: 1
00000074 20.48215675 [13920] Initializing font file enumerator: C:\Program Files (x86)\Steam\tenfoot\resource\fonts\
00000075 20.48264122 [13920] CreateCustomFontfileReference succeeded
00000076 20.48837662 [13920] CreateCustomFontfileReference succeeded
00000077 20.72313118 [13920] No cached sticky mapping in GetActionSetHandle. Native Steam Controller support won't work.
00000078 20.81058311 [13920] Found adapter AMD Radeon (TM) R9 M390X
00000079 20.81063843 [13920] Found adapter Intel(R) HD Graphics 530
00000080 20.81070518 [13920] Found adapter Microsoft Basic Render Driver
00000081 20.84043121 [13920] !! Using adapter AMD Radeon (TM) R9 M390X, GPU Mem: 3.22 GB, Sys Mem: 0 bytes, Shared Mem: 1.07 GB
00000082 20.86727905 [13920] Created ID3DX11Effect for orthographic2d.fxo from memory ok!
00000083 20.89989662 [13920] defaultfocus=DummyInput not found within layout file for welcome_nocontroller
00000084 20.90000343 [13920] defaultfocus=DummyInput not found within layout file for welcome_nocontroller
00000085 20.91007614 [13920] Loaded Config for Local Selection Path for App ID 413090: C:\Program Files (x86)\Steam\steamapps\workshop\content\241100\754616467\266097744495173226_legacy.bin
00000086 20.91067886 [13920] [413090]Non-Steam Controller Configs Enabled: 1
00000087 20.91893578 [13920] Loaded Config for Local Selection Path for App ID 413090: C:\Program Files (x86)\Steam\steamapps\workshop\content\241100\754616467\266097744495173226_legacy.bin
00000088 21.55488396 [13920] GameAction [AppID 0, ActionID 1] : LaunchApp changed task to RunningInstallScript with ""
00000089 21.55514336 [13920] GameAction [AppID 0, ActionID 1] : LaunchApp changed task to SiteLicenseSeatCheckout with ""
00000090 21.55650711 [13920] GameAction [AppID 0, ActionID 1] : LaunchApp changed task to CreatingProcess with ""
00000091 21.55654335 [13920] GameAction [AppID 0, ActionID 1] : LaunchApp waiting for user response to CreatingProcess ""
00000092 21.55657768 [13920] GameAction [AppID 0, ActionID 1] : LaunchApp continues with user response "CreatingProcess"
00000093 21.55690002 [13920] Opted-in Controller Mask: 70
00000094 21.63076973 [13920] Game update: AppID 0 "Ephinea PSOBB", ProcID 13760, IP 0.0.0.0:0
00000095 22.02332306 [13920] IPC server is in my process - could/should be using an in process pipe
00000096 22.02700233 [13920] GameAction [AppID 0, ActionID 1] : LaunchApp changed task to Completed with ""
00000097 22.04226112 [13920] >>> Adding process 13760 for game ID 33554432
00000098 22.14051437 [13920] DispatchAsyncEvent backlog, failed to dispatch all this frame. Queue depth: 1853 (1855 input number was)
00000099 22.25110626 [13920] HTTP Response for https://store.steampowered.com/api/featured/?cc=US&l=english: 200, 18472
00000100 22.28101158 [13920] DispatchAsyncEvent backlog, failed to dispatch all this frame. Queue depth: 991 (1857 input number was)
00000101 22.36098480 [13920] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\mainmenu_bg_2.png (dimensions 1920x1080, took 79 msec)
00000102 22.37811279 [13920] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\systemmenu\capsule_glow.png (dimensions 1920x1080, took 49 msec)
00000103 22.42835236 [13920] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\profile\activity_bg_wash.png (dimensions 1879x928, took 49 msec)
00000104 22.44248962 [13920] DispatchAsyncEvent backlog, failed to dispatch all this frame. Queue depth: 952 (1099 input number was)
00000105 22.44528008 [13920] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\profile\profile_bg_wash.png (dimensions 1879x928, took 65 msec)
00000106 22.46156502 [13920] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\welcomeupdates\gamesbanner.png (dimensions 1280x288, took 45 msec)
00000107 22.47842979 [13920] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\welcomeupdates\friends.png (dimensions 768x512, took 32 msec)
00000108 22.49414063 [13920] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\welcomeupdates\overlay.png (dimensions 768x512, took 31 msec)
00000109 22.49425125 [13920] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\welcomeupdates\controllerbanner.png (dimensions 1280x512, took 31 msec)
00000110 22.52829170 [13920] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\welcomeupdates\securitybanner.png (dimensions 1280x430, took 33 msec)
00000111 22.54520035 [13920] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\welcomeupdates\controller_update_overview.jpg (dimensions 1922x329, took 33 msec)
00000112 22.60898018 [13920] DispatchAsyncEvent backlog, failed to dispatch all this frame. Queue depth: 1660 (1922 input number was)
00000113 22.61114311 [13920] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\welcomeupdates\controller_update_moystick.jpg (dimensions 1922x598, took 80 msec)
00000114 22.61369133 [13920] OnFocusWindowChanged to window type: k_nGameIDControllerConfigs_Desktop, AppID 413080
00000115 22.61394119 [13920] Controller 0 Gamepad with Mouse and Gyro uses xinput : true
00000116 22.61725044 [13920] Loaded Config for Local Selection Path for App ID 413080: C:\Program Files (x86)\Steam\steamapps\workshop\content\241100\650764041/controller_configuration.vdf
00000117 22.61739922 [13920] Controller 0 Gamepad with Mouse and Gyro uses xinput : true
00000118 22.62820435 [13920] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\welcomeupdates\controller_update_mouseregions.jpg (dimensions 1922x598, took 81 msec)
00000119 22.62827492 [13920] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\welcomeupdates\controller_update_gyro_touchmenu.jpg (dimensions 1922x598, took 82 msec)
00000120 22.63032913 [13920] DispatchAsyncEvent backlog, failed to dispatch all this frame. Queue depth: 770 (1719 input number was)
00000121 22.67855644 [13920] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\welcomeupdates\controller_update_personalize.jpg (dimensions 1922x598, took 66 msec)
00000122 22.69559860 [13920] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\welcomeupdates\controller_update_hometheater.jpg (dimensions 1922x598, took 66 msec)
00000123 22.72038651 [13920] DispatchAsyncEvent backlog, failed to dispatch all this frame. Queue depth: 189 (862 input number was)
00000124 22.72804451 [13920] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\welcomeupdates\controller_update_shortcuts.jpg (dimensions 1922x598, took 98 msec)
00000125 22.76167297 [13920] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\browser\browser_reticule_outer.png (dimensions 426x426, took 33 msec)
00000126 22.82826805 [13920] Slow image load - https://steamcdn-a.akamaihd.net/steam/apps/13230/header.jpg (dimensions 460x215, took 32 msec)
00000127 22.83099556 [13920] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\background_alpha_mask.png (dimensions 1920x1080, took 35 msec)
00000128 22.84536934 [13920] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\panel_background.png (dimensions 1920x1080, took 83 msec)
00000129 22.92774200 [13920] Slow image load - https://steamcdn-a.akamaihd.net/steam/apps/10500/header.jpg (dimensions 460x215, took 31 msec)
00000130 22.92784309 [13920] Slow image load - https://steamcdn-a.akamaihd.net/steam/apps/475150/header.jpg (dimensions 460x215, took 32 msec)
00000131 22.92790794 [13920] Slow image load - https://steamcdn-a.akamaihd.net/steam/apps/13210/header.jpg (dimensions 460x215, took 32 msec)
00000132 28.43720245 [13760]
00000133 28.43720245 [13760] === Begin DirectDraw / Direct3D leak report ========
00000134 28.43720245 [13760]
00000135 28.43724823 [13760]
00000136 28.43724823 [13760] === No leaked objects were found
00000137 28.43729591 [13760]
00000138 28.43729591 [13760] === End DirectDraw / Direct3D leak report ========
00000139 28.43729591 [13760]
00000140 28.56545639 [13920] >>> Adding process 9508 for game ID 33554432
00000141 28.62959099 [13920] OnFocusWindowChanged to window type: k_nGameIDControllerConfigs_Desktop, AppID 413080
00000142 28.62967682 [13920] Controller 0 Gamepad with Mouse and Gyro uses xinput : true
00000143 28.63173103 [13920] Loaded Config for Local Selection Path for App ID 413080: C:\Program Files (x86)\Steam\steamapps\workshop\content\241100\650764041/controller_configuration.vdf
00000144 28.63190460 [13920] Controller 0 Gamepad with Mouse and Gyro uses xinput : true
00000145 30.22309685 [9508] Direct3DCreate8 (SDKVersion = dc)
00000146 30.22332764 [9508] [dgVoodoo] INFO: Reading config from file C:\Users\wiseg\EphineaPSO\dgVoodoo.conf.
00000147 30.23152733 [9508] [dgVoodoo] INFO: INI file based version of config file is successfully read.
00000148 30.23319435 [9508] [dgVoodoo] INFO: D3D8 is successfully loaded: C:\Users\wiseg\EphineaPSO\d3d8.dll
00000149 30.23337364 [9508] [dgVoodoo] WARNING: Direct3DCreate8: Attempt to access Direct3D8 from DllMain. Application may need to be modified or patched to use with dgVoodoo.
00000150 30.23344994 [9508] [dgVoodoo] INFO: Reading config from file C:\Users\wiseg\EphineaPSO\dgVoodoo.conf.
00000151 30.23367691 [9508] [dgVoodoo] INFO: INI file based version of config file is successfully read.
00000152 30.35054398 [9508] [dgVoodoo] INFO: Direct3D8 (05153AC8) DirectDraw has been loaded: C:\Users\wiseg\EphineaPSO\DDRAW.DLL
00000153 30.46465302 [9508] [dgVoodoo] INFO: Direct3D8 (05153AC8) is created. Number of display outputs (on which devices can be created): 1
00000154 30.46468735 [9508] [dgVoodoo] INFO: Direct3D8 (05153AC8) Device 0: Name: "AMD Radeon (TM) R9 M390X", Description: "\\.\DISPLAY1", Monitor rect: (0, 0, 3840, 2160), system primary monitor
00000155 30.46471596 [9508] [dgVoodoo] INFO: Direct3D8 (05153AC8) Virtual video card is 'dgVoodoo Virtual 3D Accelerated' with 64MB onboard memory.
00000156 30.46488380 [9508] Driver :AMD Radeon (TM) R9 M390X
00000157 30.46492195 [9508]
00000158 30.46834946 [9508] Description:\\.\DISPLAY1
00000159 30.46838760 [9508]
00000160 30.47177315 [9508] VendorID :00000000
00000161 30.47178841 [9508]
00000162 30.47513962 [9508] DeviceID :00000000
00000163 30.47519684 [9508]
00000164 30.47862434 [9508] SubSysID :00000000
00000165 30.47864342 [9508]
00000166 30.48253822 [9508] Revision :00000000
00000167 30.48255348 [9508]
00000168 30.89110374 [8008] ADLDirty = true
00000169 30.97186470 [8008] ADLDirty = false
00000170 30.97246742 [2032] ************Executable file path is: '
00000171 30.97305870 [9508] [dgVoodoo] INFO: Direct3DDevice8 (05233A00)::Init: Implicit swapchain (051D4A80) is created. Its display mode is 1920x1080, 32 bit, 59 Hz, fullscreen mode
00000172 30.97336960 [2032] \Device\HarddiskVolume5\Windows\System32\svchost.exe
00000173 30.97377014 [2032]
00000174 30.97436142 [2032] PID=2032
00000175 30.97495079 [2032]
00000176 30.97586823 [2032] ************Trace & dump config file path is: '
00000177 30.97644234 [2032] C:\Users\wiseg\AppData\Local\AMDh264Encoder.cfg
00000178 30.97676468 [2032] '************
00000179 30.97795868 [9508] [dgVoodoo] INFO: Direct3DDevice8 (05233A00)::Init: Requested output API type is "Best Available", DDI type is D3D 10.1, hardware accelerated
00000180 30.97815323 [9508] [dgVoodoo] INFO: Direct3DDevice8 (05233A00)::Init: Device is successfully initialized on output device index: 0. Maximum video memory: 65536 kBs, currently available video memory: 60416 kBs
00000181 30.97831726 [9508] [dgVoodoo] INFO: Direct3DDevice8 (05233A00): External shader compiler is successfully found: C:\Users\wiseg\EphineaPSO\D3DCompiler_47.dll
00000182 30.97847939 [9508] [dgVoodoo] INFO: Direct3D8 (05153AC8)::CreateDevice: Direct3DDevice8 (05233A00) is created on output device 0, device type: D3DDEVTYPE_HAL.
00000183 30.97860146 [9508] [dgVoodoo] INFO: Direct3DDevice8 (05233A00) is released.
00000184 30.97945023 [9508] [dgVoodoo] INFO: Direct3DSwapchain8 (051D4A80) is released.
00000185 31.62531281 [8008] ADLDirty = true
00000186 31.62774467 [8008] ADLDirty = false
00000187 31.79450607 [9508] [dgVoodoo] INFO: Direct3DDevice8 (0B7A09D0)::Init: Implicit swapchain (052954D0) is created. Its display mode is 1920x1080, 32 bit, 59 Hz, fullscreen mode
00000188 31.79640388 [9508] [dgVoodoo] INFO: Direct3DDevice8 (0B7A09D0)::Init: Requested output API type is "Best Available", DDI type is D3D 10.1, hardware accelerated
00000189 31.79644394 [9508] [dgVoodoo] INFO: Direct3DDevice8 (0B7A09D0)::Init: Device is successfully initialized on output device index: 0. Maximum video memory: 65536 kBs, currently available video memory: 60416 kBs
00000190 31.79648972 [9508] [dgVoodoo] INFO: Direct3DDevice8 (0B7A09D0): External shader compiler is successfully found: C:\Users\wiseg\EphineaPSO\D3DCompiler_47.dll
00000191 31.79656410 [9508] [dgVoodoo] INFO: Direct3D8 (05153AC8)::CreateDevice: Direct3DDevice8 (0B7A09D0) is created on output device 0, device type: D3DDEVTYPE_HAL.
00000192 31.79661179 [9508] DEVICE :HAL-HARD
00000193 31.79664040 [9508]
00000194 31.81316185 [8008] ADLDirty = true
00000195 31.82819557 [8008] ADLDirty = false
00000196 31.85976028 [13920] OnFocusWindowChanged to window type: k_nGameIDControllerConfigs_Desktop, AppID 413080
00000197 31.85985565 [13920] Controller 0 Gamepad with Mouse and Gyro uses xinput : true
00000198 31.86134720 [13920] Loaded Config for Local Selection Path for App ID 413080: C:\Program Files (x86)\Steam\steamapps\workshop\content\241100\650764041/controller_configuration.vdf
00000199 31.86145020 [13920] Controller 0 Gamepad with Mouse and Gyro uses xinput : true
00000200 31.99248886 [9508] [dgVoodoo] INFO: Direct3DDevice8 (0B7A09D0)::CreateTexture: Direct3DTexture8 (0B742CA0, IDirect3DTexture8 = 0B742D64) is created.
00000201 31.99451828 [9508] [dgVoodoo] INFO: Direct3DDevice8 (0B7A09D0)::CreateTexture: Direct3DTexture8 (052800E8, IDirect3DTexture8 = 052801AC) is created.
00000202 31.99512672 [9508] [dgVoodoo] INFO: Direct3DDevice8 (0B7A09D0)::CreateTexture: Direct3DTexture8 (0B809688, IDirect3DTexture8 = 0B80974C) is created.
00000203 32.05486298 [9508] [dgVoodoo] INFO: Direct3DDevice8 (0B7A09D0)::CreateTexture: Direct3DTexture8 (0B8152F8, IDirect3DTexture8 = 0B8153BC) is created.
00000204 32.05563354 [9508] [dgVoodoo] INFO: Direct3DDevice8 (0B7A09D0)::CreateTexture: Direct3DTexture8 (0B84D938, IDirect3DTexture8 = 0B84D9FC) is created.
00000205 32.05595016 [9508] [dgVoodoo] INFO: Direct3DDevice8 (0B7A09D0)::CreateTexture: Direct3DTexture8 (0B84DCE8, IDirect3DTexture8 = 0B84DDAC) is created.
00000206 32.12069321 [6796] Suspending
00000207 32.16239166 [7324] Failed to log to file
00000208 32.16948318 [7324] Failed to log to file
00000209 32.18873215 [7324] Failed to file tracing file
00000210 32.39751053 [13920] Found adapter AMD Radeon (TM) R9 M390X
00000211 32.39756775 [13920] Found adapter Intel(R) HD Graphics 530
00000212 32.39762115 [13920] Found adapter Microsoft Basic Render Driver
00000213 32.43791962 [13920] !! Using adapter AMD Radeon (TM) R9 M390X, GPU Mem: 3.22 GB, Sys Mem: 0 bytes, Shared Mem: 1.07 GB
00000214 32.45652771 [13920] Created ID3DX11Effect for orthographic2d.fxo from memory ok!
00000215 32.46441650 [13920] Found adapter AMD Radeon (TM) R9 M390X
00000216 32.46450806 [13920] Found adapter Intel(R) HD Graphics 530
00000217 32.46453857 [13920] Found adapter Microsoft Basic Render Driver
00000218 32.50388336 [13920] !! Using adapter AMD Radeon (TM) R9 M390X, GPU Mem: 3.22 GB, Sys Mem: 0 bytes, Shared Mem: 1.07 GB
00000219 32.51204300 [13920] Created ID3DX11Effect for orthographic2d.fxo from memory ok!
00000220 32.72405624 [13920] Found adapter AMD Radeon (TM) R9 M390X
00000221 32.72412491 [13920] Found adapter Intel(R) HD Graphics 530
00000222 32.72420120 [13920] Found adapter Microsoft Basic Render Driver
00000223 32.75801468 [13920] !! Using adapter AMD Radeon (TM) R9 M390X, GPU Mem: 3.22 GB, Sys Mem: 0 bytes, Shared Mem: 1.07 GB
00000224 32.76571655 [13920] Created ID3DX11Effect for orthographic2d.fxo from memory ok!
00000225 32.78184509 [13920] DispatchAsyncEvent backlog, failed to dispatch all this frame. Queue depth: 1100 (1102 input number was)
00000226 32.81112671 [13920] !! Controller 0 attributes:
00000227 32.81112671 [13920] Type: 2
00000228 32.81112671 [13920] ProductID: 4354
00000229 32.81112671 [13920] Serial: FC619203BC
00000230 32.81112671 [13920] Capabilities: 00013ff7
00000231 32.81112671 [13920] Firmware Version: 0
00000232 32.81112671 [13920] Firmware Build Time: 1527718333 (Wed, 30 May 2018 22:12:13 GMT)
00000233 32.81112671 [13920] Bootloader Build Time: 1439863405 (Tue, 18 Aug 2015 02:03:25 GMT)
00000234 32.81204605 [13920] OnFocusWindowChanged to game window type: AppID 2147483649, ephinea psobb
00000235 32.81216812 [13920] Controller 0 Gamepad with Mouse and Gyro uses xinput : true
00000236 32.81546021 [13920] Loaded Config for Local Selection Path for App ID -2147483647: C:\Program Files (x86)\Steam\steamapps\workshop\content\241100\1459950924\957464882662497763_legacy.bin
00000237 32.81565094 [13920] Controller 0 Gamepad with Mouse and Gyro uses xinput : true
00000238 32.86642075 [13920] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\profile\activity_bg_wash.png (dimensions 1879x928, took 44 msec)
00000239 32.90610504 [13920] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\profile\profile_bg_wash.png (dimensions 1879x928, took 84 msec)
00000240 32.92782974 [13920] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\mainmenu_bg_2.png (dimensions 1920x1080, took 110 msec)
00000241 32.95402908 [13232] [000:00:00:000][P][GameBarUpdateTask][0x000035a0] GameBarUpdateTask::RegisterTasks has been invoked.
00000242 32.97124100 [13920] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\overlay\overlay_bg_wash.png (dimensions 1879x928, took 63 msec)
00000243 32.97647095 [13920] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\panel_background.png (dimensions 1920x1080, took 72 msec)
00000244 32.98349762 [13232] [000:00:00:029][P][BackgroundTaskManager][0x000035a0] BroadcastBackgroundTask: Broadcast background task already registered.
00000245 32.98380661 [13232] [000:00:00:029][P][BackgroundTaskManager][0x000035a0] BackgroundTaskManager::RegisterBroadcastBackgroundTask. Unregistering the existing task that was found.
00000246 32.98583984 [13920] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\background_alpha_mask.png (dimensions 1920x1080, took 32 msec)
00000247 32.98775482 [13232] [000:00:00:033][P][BackgroundTaskManager][0x000035a0] BackgroundTaskManager. IsBroadcastingAllowed: true
00000248 32.98781586 [13232] [000:00:00:033][P][BackgroundTaskManager][0x000035a0] BackgroundTaskManager::RegisterBroadcastBackgroundTask. Registering broadcast task now.
00000249 33.03797531 [13232] [000:00:00:083][P][BackgroundTaskManager][0x000035a0] BroadcastBackgroundTask: Broadcast background task successfully registered.
00000250 33.38160706 [13920] HTTP Response for https://steamcommunity-a.akamaihd.net/news/newsforapp/v0001/?appid=2147483649&count=5&maxlength=500&format=json: 403, 0
00000251 33.38167572 [13920] HTTP Response failed https://steamcommunity-a.akamaihd.net/news/newsforapp/v0001/?appid=2147483649&count=5&maxlength=500&format=json
00000252 35.99900818 [13920] Warning: The game hasn't rendered a frame from us in over 10 seconds
00000253 48.82380676 [13920] Warning: The game hasn't rendered a frame from us in over 10 seconds
the last thing I saw was a black screen I could not switch from, with the dgVoodoo 2 logo in the lower right hand corner, forcing me to reboot my machine. I did so about 10-20 seconds after the black screen appeared, which appeared when I launched PSOBB in classic fullscreen mode.
by the way PSOBB is a free game to download on the Ephinea server. so try it yourself. do not post here trying to offer tech support unless you have the game installed, try various resolutions and settings with WINDOW MODE DISABLED and CLASSIC FULLSCREEN ENABLED in PSOBB.
Reply 14 of 33, by todd
also using the DEFAULT dgVoodoo 2 settings, PSOBB refuses to start up at all when you use the NATIVE RESOLUTION OF 4K or qHD. I am seeing an error about being out of video memory. this must be because 4K is too much for the adapters default of 64MB:
[\\DESKTOP-HKAVRA7]
00000001 0.00000000 [11928] RecursiveDirectoryCreate( C:\Users\wiseg\AppData\Local\CEF\User Data directory exists )
00000002 0.04773860 [12624] IPC server is in my process - could/should be using an in process pipe
00000003 0.08995420 [11928] [0812/184022.600:INFO:crash_reporting.cc(215)] Crash reporting enabled for process: browser
00000004 0.10234600 [12624] CApplicationManagerPopulateThread took 2 milliseconds to initialize (will have waited on CAppInfoCacheReadFromDiskThread)
00000005 0.14196239 [11928] [0812/184022.647:ERROR:gpu_process_transport_factory.cc(1029)] Lost UI shared context.
00000006 0.15480261 [12624] CAppInfoCacheReadFromDiskThread took 68 milliseconds to initialize
00000007 0.18294939 [12624] CHTTPRequestCache took 82 milliseconds to initialize
00000008 1.12478936 [12624] Local Device Found
00000009 1.12478936 [12624] type: 28de 1102
00000010 1.12478936 [12624] path: \\?\hid#vid_28de&pid_1102&mi_02#7&3abbaa23&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}
00000011 1.12478936 [12624] serial_number: - 0
00000012 1.12486351 [12624] Manufacturer: Valve Software
00000013 1.12488723 [12624] Product: Valve
00000014 1.12493944 [12624] Release: 100
00000015 1.12503159 [12624] Interface: 2
00000016 1.12503159 [12624]
00000017 1.12514555 [12624] Controller uses V1 HID protocol
00000018 1.12523603 [12624] !! Steam controller device opened for index 0.
00000019 1.12552440 [12624] Steam Controller reserving XInput slot 0
00000020 1.18860137 [12624] Controller 0 connected, configuring it now...
00000021 1.63487911 [12624] Chip ID: 308002186794abaec6a43255401900f5
00000022 1.68409884 [12624] BYieldingQueryAccountsRegisteredToController
00000023 1.75106680 [12624] !! Controller 0 attributes:
00000024 1.75106680 [12624] Type: 2
00000025 1.75106680 [12624] ProductID: 4354
00000026 1.75106680 [12624] Serial: FC619203BC
00000027 1.75106680 [12624] Capabilities: 00013ff7
00000028 1.75106680 [12624] Firmware Version: 0
00000029 1.75106680 [12624] Firmware Build Time: 1527718333 (Wed, 30 May 2018 22:12:13 GMT)
00000030 1.75106680 [12624] Bootloader Build Time: 1439863405 (Tue, 18 Aug 2015 02:03:25 GMT)
00000031 1.75332439 [12624] Could not load local selection (), local override (C:\Program Files (x86)\Steam/controller_config/bigpicture.vdf), or user path (C:\Program Files (x86)\Steam/appcache//controller_configs/bigpicture.vdf), checking last resort path: C:\Program Files (x86)\Steam/controller_base/bigpicture.vdf
00000032 1.76206636 [12624] Loaded Config for Last Resort Path for App ID 413090: C:\Program Files (x86)\Steam/controller_base/bigpicture.vdf
00000033 1.76927841 [12624] Could not load local selection (), local override (C:\Program Files (x86)\Steam/controller_config/bigpicture.vdf), or user path (C:\Program Files (x86)\Steam/appcache//controller_configs/bigpicture.vdf), checking last resort path: C:\Program Files (x86)\Steam/controller_base/bigpicture.vdf
00000034 1.77227819 [12624] Loaded Config for Last Resort Path for App ID 413090: C:\Program Files (x86)\Steam/controller_base/bigpicture.vdf
00000035 1.77403641 [12624] Could not load local selection (), local override (C:\Program Files (x86)\Steam/controller_config/steamdesktop.vdf), or user path (C:\Program Files (x86)\Steam/appcache//controller_configs/steamdesktop.vdf), checking last resort path: C:\Program Files (x86)\Steam/controller_base/steamdesktop.vdf
00000036 1.77921963 [12624] Loaded Config for Last Resort Path for App ID 413080: C:\Program Files (x86)\Steam/controller_base/steamdesktop.vdf
00000037 1.78031802 [12624] Controller 0 mapping uses xinput : false
00000038 6.73048162 [11928] Found unsupported CDM version 1.4.9.1088, using last known good version 1.4.8.1008
00000039 11.64793587 [12624] Loaded Config for Local Selection Path for App ID 413080: C:\Program Files (x86)\Steam\steamapps\workshop\content\241100\650764041/controller_configuration.vdf
00000040 11.64853668 [12624] [413080]Non-Steam Controller Configs Enabled: 1
00000041 11.65106487 [12624] local (potentially out of sync) copy of roaming config loaded - 3693 bytes.
00000042 12.37659740 [12624] roaming config store loaded successfully - 3693 bytes.
00000043 12.37692642 [12624] migrating temporary roaming config store
00000044 12.57612801 [12412] [0812/184035.086:INFO:crash_reporting.cc(215)] Crash reporting enabled for process: gpu-process
00000045 12.59643173 [12416] [0812/184035.106:INFO:crash_reporting.cc(215)] Crash reporting enabled for process: renderer
00000046 13.06160355 [12624] Failed to init SteamVR because it isn't installed
00000047 13.13765240 [12624] ExecCommandLine: ""C:\Program Files (x86)\Steam\Steam.exe""
00000048 14.01604176 [12624] IPC server is in my process - could/should be using an in process pipe
00000049 14.02343655 [12624] System startup time: 14.15 seconds
00000050 14.02413082 [12624] !! Controller 0 attributes:
00000051 14.02413082 [12624] Type: 2
00000052 14.02413082 [12624] ProductID: 4354
00000053 14.02413082 [12624] Serial: FC619203BC
00000054 14.02413082 [12624] Capabilities: 00013ff7
00000055 14.02413082 [12624] Firmware Version: 0
00000056 14.02413082 [12624] Firmware Build Time: 1527718333 (Wed, 30 May 2018 22:12:13 GMT)
00000057 14.02413082 [12624] Bootloader Build Time: 1439863405 (Tue, 18 Aug 2015 02:03:25 GMT)
00000058 14.02482224 [12624] Fetching Config Sets 0
00000059 14.02494240 [12624] CClientJobFetchPersonalizationFileID
…Show last 304 lines
00000060	14.02843666	[12624] Blocking global navigation to: data:text/html,%3Cbody%3E%3C%2Fbody%3E
00000061 14.10999012 [12892] [0812/184036.619:INFO:crash_reporting.cc(215)] Crash reporting enabled for process: renderer
00000062 14.24090385 [12624] Set Account Config Sets 0 1 1
00000063 14.46912193 [12624] OnFocusWindowChanged to window type: k_nGameIDControllerConfigs_Desktop, AppID 413080
00000064 14.47226429 [12624] Loaded Config for Local Selection Path for App ID 413080: C:\Program Files (x86)\Steam\steamapps\workshop\content\241100\650764041/controller_configuration.vdf
00000065 14.47264290 [12624] [413080]Non-Steam Controller Configs Enabled: 1
00000066 14.47340679 [12624] OnFocusWindowChanged to window type: k_nGameIDControllerConfigs_Desktop, AppID 413080
00000067 14.47504807 [12624] Loaded Config for Local Selection Path for App ID 413080: C:\Program Files (x86)\Steam\steamapps\workshop\content\241100\650764041/controller_configuration.vdf
00000068 14.54109287 [12624] CAPIJobRequestUserStats - Server response failed 2
00000069 15.38687229 [12624] [413080-650764041]: Failed to start tracking playtime
00000070 15.53605461 [12624] [413080-650764041]: Failed to start tracking playtime
00000071 17.05288696 [12624] Loaded Config for Local Selection Path for App ID -2147483647: C:\Program Files (x86)\Steam\steamapps\workshop\content\241100\1459950924\957464882662497763_legacy.bin
00000072 17.05325508 [12624] [2147483649]Non-Steam Controller Configs Enabled: 1
00000073 17.10480690 [12624] Initializing font file enumerator: C:\Program Files (x86)\Steam\tenfoot\resource\fonts\
00000074 17.10491753 [12624] CreateCustomFontfileReference succeeded
00000075 17.11126709 [12624] CreateCustomFontfileReference succeeded
00000076 17.35015106 [12624] No cached sticky mapping in GetActionSetHandle. Native Steam Controller support won't work.
00000077 17.43824768 [12624] Found adapter AMD Radeon (TM) R9 M390X
00000078 17.43832016 [12624] Found adapter Intel(R) HD Graphics 530
00000079 17.43837357 [12624] Found adapter Microsoft Basic Render Driver
00000080 17.46815109 [12624] !! Using adapter AMD Radeon (TM) R9 M390X, GPU Mem: 3.22 GB, Sys Mem: 0 bytes, Shared Mem: 1.07 GB
00000081 17.49493408 [12624] Created ID3DX11Effect for orthographic2d.fxo from memory ok!
00000082 17.52921867 [12624] defaultfocus=DummyInput not found within layout file for welcome_nocontroller
00000083 17.52933693 [12624] defaultfocus=DummyInput not found within layout file for welcome_nocontroller
00000084 17.53961372 [12624] Loaded Config for Local Selection Path for App ID 413090: C:\Program Files (x86)\Steam\steamapps\workshop\content\241100\754616467\266097744495173226_legacy.bin
00000085 17.54001999 [12624] [413090]Non-Steam Controller Configs Enabled: 1
00000086 17.54772758 [12624] Loaded Config for Local Selection Path for App ID 413090: C:\Program Files (x86)\Steam\steamapps\workshop\content\241100\754616467\266097744495173226_legacy.bin
00000087 18.17680550 [12624] GameAction [AppID 0, ActionID 1] : LaunchApp changed task to RunningInstallScript with ""
00000088 18.17709351 [12624] GameAction [AppID 0, ActionID 1] : LaunchApp changed task to SiteLicenseSeatCheckout with ""
00000089 18.17924500 [12624] GameAction [AppID 0, ActionID 1] : LaunchApp changed task to CreatingProcess with ""
00000090 18.17930984 [12624] GameAction [AppID 0, ActionID 1] : LaunchApp waiting for user response to CreatingProcess ""
00000091 18.17937279 [12624] GameAction [AppID 0, ActionID 1] : LaunchApp continues with user response "CreatingProcess"
00000092 18.17959976 [12624] Opted-in Controller Mask: 70
00000093 18.25487518 [12624] Game update: AppID 0 "Ephinea PSOBB", ProcID 12968, IP 0.0.0.0:0
00000094 19.01034927 [12624] IPC server is in my process - could/should be using an in process pipe
00000095 19.01394844 [12624] GameAction [AppID 0, ActionID 1] : LaunchApp changed task to Completed with ""
00000096 19.02272034 [12624] >>> Adding process 12968 for game ID 33554432
00000097 19.13959122 [12624] DispatchAsyncEvent backlog, failed to dispatch all this frame. Queue depth: 1853 (1855 input number was)
00000098 19.24167633 [12624] HTTP Response for https://store.steampowered.com/api/featured/?cc=US&l=english: 200, 18472
00000099 19.25896835 [12624] OnFocusWindowChanged to window type: k_nGameIDControllerConfigs_Desktop, AppID 413080
00000100 19.25908470 [12624] Controller 0 Gamepad with Mouse and Gyro uses xinput : true
00000101 19.26090813 [12624] Loaded Config for Local Selection Path for App ID 413080: C:\Program Files (x86)\Steam\steamapps\workshop\content\241100\650764041/controller_configuration.vdf
00000102 19.26109695 [12624] Controller 0 Gamepad with Mouse and Gyro uses xinput : true
00000103 19.27746964 [12624] DispatchAsyncEvent backlog, failed to dispatch all this frame. Queue depth: 1433 (1857 input number was)
00000104 19.34740257 [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\systemmenu\capsule_glow.png (dimensions 1920x1080, took 32 msec)
00000105 19.37967110 [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\systemmenu\icon_community.png (dimensions 200x200, took 31 msec)
00000106 19.37978745 [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\mainmenu_bg_2.png (dimensions 1920x1080, took 97 msec)
00000107 19.38005829 [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\systemmenu\icon_friends.png (dimensions 200x200, took 30 msec)
00000108 19.41271591 [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\library\icon_search.png (dimensions 64x64, took 31 msec)
00000109 19.43171120 [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\profile\profile_bg_wash.png (dimensions 1879x928, took 50 msec)
00000110 19.43181038 [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\profile\activity_bg_wash.png (dimensions 1879x928, took 51 msec)
00000111 19.46904564 [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\welcomeupdates\gamesbanner.png (dimensions 1280x288, took 50 msec)
00000112 19.47827148 [12624] DispatchAsyncEvent backlog, failed to dispatch all this frame. Queue depth: 1617 (2469 input number was)
00000113 19.48179054 [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\welcomeupdates\friends.png (dimensions 768x512, took 47 msec)
00000114 19.49871063 [12624] DispatchAsyncEvent backlog, failed to dispatch all this frame. Queue depth: 978 (1700 input number was)
00000115 19.51461601 [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\welcomeupdates\controllerbanner.png (dimensions 1280x512, took 32 msec)
00000116 19.51620293 [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\welcomeupdates\overlay.png (dimensions 768x512, took 34 msec)
00000117 19.54335594 [12624] DispatchAsyncEvent backlog, failed to dispatch all this frame. Queue depth: 536 (1058 input number was)
00000118 19.54781342 [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\welcomeupdates\securitybanner.png (dimensions 1280x430, took 32 msec)
00000119 19.58134270 [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\welcomeupdates\controller_update_overview.jpg (dimensions 1922x329, took 49 msec)
00000120 19.61446571 [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\welcomeupdates\controller_update_moystick.jpg (dimensions 1922x598, took 64 msec)
00000121 19.64783287 [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\welcomeupdates\controller_update_gyro_touchmenu.jpg (dimensions 1922x598, took 81 msec)
00000122 19.64797020 [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\welcomeupdates\controller_update_mouseregions.jpg (dimensions 1922x598, took 65 msec)
00000123 19.68060684 [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\welcomeupdates\controller_update_personalize.jpg (dimensions 1922x598, took 65 msec)
00000124 19.71451187 [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\welcomeupdates\controller_update_shortcuts.jpg (dimensions 1922x598, took 65 msec)
00000125 19.71461678 [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\welcomeupdates\controller_update_hometheater.jpg (dimensions 1922x598, took 65 msec)
00000126 19.74780464 [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\browser\browser_reticule_outer.png (dimensions 426x426, took 32 msec)
00000127 19.74790192 [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\browser\favorite_added.png (dimensions 512x512, took 32 msec)
00000128 19.83151436 [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\panel_background.png (dimensions 1920x1080, took 65 msec)
00000129 19.84789848 [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\background_alpha_mask.png (dimensions 1920x1080, took 49 msec)
00000130 19.89805603 [12624] Slow image load - https://steamcdn-a.akamaihd.net/steam/apps/212480/header.jpg (dimensions 460x215, took 31 msec)
00000131 19.89810181 [12624] Slow image load - https://steamcdn-a.akamaihd.net/steam/apps/71250/header.jpg (dimensions 460x215, took 31 msec)
00000132 37.16056061 [12968]
00000133 37.16056061 [12968] === Begin DirectDraw / Direct3D leak report ========
00000134 37.16056061 [12968]
00000135 37.16060257 [12968]
00000136 37.16060257 [12968] === No leaked objects were found
00000137 37.16063690 [12968]
00000138 37.16063690 [12968] === End DirectDraw / Direct3D leak report ========
00000139 37.16063690 [12968]
00000140 37.33926773 [12624] >>> Adding process 1884 for game ID 33554432
00000141 37.40284348 [12624] OnFocusWindowChanged to window type: k_nGameIDControllerConfigs_Desktop, AppID 413080
00000142 37.40302277 [12624] Controller 0 Gamepad with Mouse and Gyro uses xinput : true
00000143 37.40530014 [12624] Loaded Config for Local Selection Path for App ID 413080: C:\Program Files (x86)\Steam\steamapps\workshop\content\241100\650764041/controller_configuration.vdf
00000144 37.40536499 [12624] Controller 0 Gamepad with Mouse and Gyro uses xinput : true
00000145 40.44532013 [1884] Direct3DCreate8 (SDKVersion = dc)
00000146 40.44569778 [1884] [dgVoodoo] INFO: Reading config from file C:\Users\wiseg\EphineaPSO\dgVoodoo.conf.
00000147 40.45311737 [1884] [dgVoodoo] INFO: INI file based version of config file is successfully read.
00000148 40.45486069 [1884] [dgVoodoo] INFO: D3D8 is successfully loaded: C:\Users\wiseg\EphineaPSO\d3d8.dll
00000149 40.45495605 [1884] [dgVoodoo] WARNING: Direct3DCreate8: Attempt to access Direct3D8 from DllMain. Application may need to be modified or patched to use with dgVoodoo.
00000150 40.45502853 [1884] [dgVoodoo] INFO: Reading config from file C:\Users\wiseg\EphineaPSO\dgVoodoo.conf.
00000151 40.45522308 [1884] [dgVoodoo] INFO: INI file based version of config file is successfully read.
00000152 40.55678940 [1884] [dgVoodoo] INFO: Direct3D8 (0599EFD8) DirectDraw has been loaded: C:\Users\wiseg\EphineaPSO\DDRAW.DLL
00000153 40.68557358 [1884] [dgVoodoo] INFO: Direct3D8 (0599EFD8) is created. Number of display outputs (on which devices can be created): 1
00000154 40.68573761 [1884] [dgVoodoo] INFO: Direct3D8 (0599EFD8) Device 0: Name: "AMD Radeon (TM) R9 M390X", Description: "\\.\DISPLAY1", Monitor rect: (0, 0, 3840, 2160), system primary monitor
00000155 40.68575287 [1884] [dgVoodoo] INFO: Direct3D8 (0599EFD8) Virtual video card is 'dgVoodoo Virtual 3D Accelerated' with 64MB onboard memory.
00000156 40.68590164 [1884] Driver :AMD Radeon (TM) R9 M390X
00000157 40.68604279 [1884]
00000158 40.68931198 [1884] Description:\\.\DISPLAY1
00000159 40.68944168 [1884]
00000160 40.69241714 [1884] VendorID :00000000
00000161 40.69253922 [1884]
00000162 40.69543839 [1884] DeviceID :00000000
00000163 40.69556427 [1884]
00000164 40.69824600 [1884] SubSysID :00000000
00000165 40.69836807 [1884]
00000166 40.70102310 [1884] Revision :00000000
00000167 40.70108032 [1884]
00000168 40.71638870 [1884] [dgVoodoo] ERROR: Direct3DDevice8 (05A7FC80)::Init/CreateAdditionalSwapChain: Out of videomemory, cannot create swapchain. Required bytes: 99532800, remained bytes: 61865984.
00000169 40.71645355 [1884] [dgVoodoo] ERROR: Direct3DDevice8 (05A7FC80)::Init: Cannot create device implicit swapchain.
00000170 40.71655273 [1884] [dgVoodoo] ERROR: Direct3D8 (0599EFD8)::CreateDevice: Initializing Direct3DDevice8 (05A7FC80) failed.
00000171 40.71681213 [1884] [dgVoodoo] ERROR: Direct3DDevice8 (0AFB2008)::Init/CreateAdditionalSwapChain: Out of videomemory, cannot create swapchain. Required bytes: 99532800, remained bytes: 61865984.
00000172 40.71690369 [1884] [dgVoodoo] ERROR: Direct3DDevice8 (0AFB2008)::Init: Cannot create device implicit swapchain.
00000173 40.71693420 [1884] [dgVoodoo] ERROR: Direct3D8 (0599EFD8)::CreateDevice: Initializing Direct3DDevice8 (0AFB2008) failed.
00000174 40.71727371 [1884] [dgVoodoo] ERROR: Direct3DDevice8 (0AFB2008)::Init/CreateAdditionalSwapChain: Out of videomemory, cannot create swapchain. Required bytes: 99532800, remained bytes: 61865984.
00000175 40.71736908 [1884] [dgVoodoo] ERROR: Direct3DDevice8 (0AFB2008)::Init: Cannot create device implicit swapchain.
00000176 40.71742630 [1884] [dgVoodoo] ERROR: Direct3D8 (0599EFD8)::CreateDevice: Initializing Direct3DDevice8 (0AFB2008) failed.
00000177 40.71802521 [1884] [dgVoodoo] ERROR: Direct3DDevice8 (0AFB2008)::Init/CreateAdditionalSwapChain: Out of videomemory, cannot create swapchain. Required bytes: 82944000, remained bytes: 61865984.
00000178 40.71805191 [1884] [dgVoodoo] ERROR: Direct3DDevice8 (0AFB2008)::Init: Cannot create device implicit swapchain.
00000179 40.71813583 [1884] [dgVoodoo] ERROR: Direct3D8 (0599EFD8)::CreateDevice: Initializing Direct3DDevice8 (0AFB2008) failed.
00000180 40.71837234 [1884] [dgVoodoo] ERROR: Direct3DDevice8 (0AFB2008)::Init/CreateAdditionalSwapChain: Out of videomemory, cannot create swapchain. Required bytes: 82944000, remained bytes: 61865984.
00000181 40.71849060 [1884] [dgVoodoo] ERROR: Direct3DDevice8 (0AFB2008)::Init: Cannot create device implicit swapchain.
00000182 40.71855927 [1884] [dgVoodoo] ERROR: Direct3D8 (0599EFD8)::CreateDevice: Initializing Direct3DDevice8 (0AFB2008) failed.
00000183 40.71881866 [1884] [dgVoodoo] ERROR: Direct3DDevice8 (0AFB2008)::Init/CreateAdditionalSwapChain: Out of videomemory, cannot create swapchain. Required bytes: 82944000, remained bytes: 61865984.
00000184 40.71884155 [1884] [dgVoodoo] ERROR: Direct3DDevice8 (0AFB2008)::Init: Cannot create device implicit swapchain.
00000185 40.71891022 [1884] [dgVoodoo] ERROR: Direct3D8 (0599EFD8)::CreateDevice: Initializing Direct3DDevice8 (0AFB2008) failed.
00000186 40.71893311 [1884] Fail Direct3DCreateDevice
00000187 40.71895218 [1884]
00000188 40.72835922 [1884] [dgVoodoo] WARNING: Direct3DCreate8: Attempt to access Direct3D8 from DllMain. Application may need to be modified or patched to use with dgVoodoo.
00000189 40.73173904 [1884] [dgVoodoo] INFO: Direct3D8 (059DDE98) is created. Number of display outputs (on which devices can be created): 1
00000190 40.73186874 [1884] [dgVoodoo] INFO: Direct3D8 (059DDE98) Device 0: Name: "AMD Radeon (TM) R9 M390X", Description: "\\.\DISPLAY1", Monitor rect: (0, 0, 3840, 2160), system primary monitor
00000191 40.73211670 [1884] [dgVoodoo] INFO: Direct3D8 (059DDE98) Virtual video card is 'dgVoodoo Virtual 3D Accelerated' with 64MB onboard memory.
00000192 40.73261642 [1884] Driver :AMD Radeon (TM) R9 M390X
00000193 40.73263550 [1884]
00000194 40.73577881 [1884] Description:\\.\DISPLAY1
00000195 40.73589706 [1884]
00000196 40.73875809 [1884] VendorID :00000000
00000197 40.73888779 [1884]
00000198 40.74181747 [1884] DeviceID :00000000
00000199 40.74192810 [1884]
00000200 40.74475861 [1884] SubSysID :00000000
00000201 40.74488831 [1884]
00000202 40.74781418 [1884] Revision :00000000
00000203 40.74792480 [1884]
00000204 40.76404190 [1884]
00000205 40.76404190 [1884] === Begin DirectDraw / Direct3D leak report ========
00000206 40.76404190 [1884]
00000207 40.76455307 [1884]
00000208 40.76455307 [1884] === No leaked objects were found
00000209 40.76474762 [1884]
00000210 40.76474762 [1884] === End DirectDraw / Direct3D leak report ========
00000211 40.76474762 [1884]
00000212 40.89038086 [1884] [dgVoodoo] WARNING: Leaked D3D8 objects detected at unloading D3D8 (probably process exit)!
00000213 43.12639999 [12624] Game removed: AppID 0 "Ephinea PSOBB", ProcID 12968
00000214 43.17207718 [12624] Loaded Config for Local Selection Path for App ID 413080: C:\Program Files (x86)\Steam\steamapps\workshop\content\241100\650764041/controller_configuration.vdf
00000215 43.25959015 [12624] saving roaming config store to 'sharedconfig.vdf'
00000216 43.28545761 [12624] roaming config store 2 saved successfully
00000217 43.28706360 [12624] **** Panel FavoritePages has fill-parent-flow for height, but isn't in a flowing down or up layout
00000218 44.74097443 [12624] Loaded Config for Local Selection Path for App ID -2147483647: C:\Program Files (x86)\Steam\steamapps\workshop\content\241100\1459950924\957464882662497763_legacy.bin
00000219 44.78536987 [12624] Initializing font file enumerator: C:\Program Files (x86)\Steam\tenfoot\resource\fonts\
00000220 44.78544998 [12624] CreateCustomFontfileReference succeeded
00000221 44.78570175 [12624] CreateCustomFontfileReference succeeded
00000222 44.95258331 [12624] Warning: DirectSound playback reset due to non-moving playback cursor (buggy sound driver) time: 27693 play: 0 write: 0.
00000223 45.00438309 [12624] Found adapter AMD Radeon (TM) R9 M390X
00000224 45.00447464 [12624] Found adapter Intel(R) HD Graphics 530
00000225 45.00452042 [12624] Found adapter Microsoft Basic Render Driver
00000226 45.03282928 [12624] !! Using adapter AMD Radeon (TM) R9 M390X, GPU Mem: 3.22 GB, Sys Mem: 0 bytes, Shared Mem: 1.07 GB
00000227 45.04304504 [12624] Created ID3DX11Effect for orthographic2d.fxo from memory ok!
00000228 45.05223846 [12624] defaultfocus=DummyInput not found within layout file for welcome_nocontroller
00000229 45.05241013 [12624] defaultfocus=DummyInput not found within layout file for welcome_nocontroller
00000230 45.05720139 [12624] Loaded Config for Local Selection Path for App ID 413090: C:\Program Files (x86)\Steam\steamapps\workshop\content\241100\754616467\266097744495173226_legacy.bin
00000231 45.06124115 [12624] Loaded Config for Local Selection Path for App ID 413090: C:\Program Files (x86)\Steam\steamapps\workshop\content\241100\754616467\266097744495173226_legacy.bin
00000232 45.19448471 [12624] GameAction [AppID 0, ActionID 2] : LaunchApp changed task to RunningInstallScript with ""
00000233 45.19481277 [12624] GameAction [AppID 0, ActionID 2] : LaunchApp changed task to SiteLicenseSeatCheckout with ""
00000234 45.19810486 [12624] GameAction [AppID 0, ActionID 2] : LaunchApp changed task to CreatingProcess with ""
00000235 45.19814682 [12624] GameAction [AppID 0, ActionID 2] : LaunchApp waiting for user response to CreatingProcess ""
00000236 45.19817352 [12624] GameAction [AppID 0, ActionID 2] : LaunchApp continues with user response "CreatingProcess"
00000237 45.19844818 [12624] Opted-in Controller Mask: 70
00000238 45.20829010 [12624] Game update: AppID 0 "Ephinea PSOBB", ProcID 8928, IP 0.0.0.0:0
00000239 45.21203995 [12624] GameAction [AppID 0, ActionID 2] : LaunchApp changed task to Completed with ""
00000240 45.21303177 [12624] >>> Adding process 8928 for game ID 33554432
00000241 45.33587265 [12624] DispatchAsyncEvent backlog, failed to dispatch all this frame. Queue depth: 1853 (1855 input number was)
00000242 45.45837784 [12624] DispatchAsyncEvent backlog, failed to dispatch all this frame. Queue depth: 1432 (1856 input number was)
00000243 45.49997330 [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\systemmenu\capsule_glow.png (dimensions 1920x1080, took 45 msec)
00000244 45.51745605 [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\mainmenu_bg_2.png (dimensions 1920x1080, took 66 msec)
00000245 45.56654358 [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\profile\activity_bg_wash.png (dimensions 1879x928, took 49 msec)
00000246 45.58340073 [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\profile\profile_bg_wash.png (dimensions 1879x928, took 66 msec)
00000247 45.58633423 [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\welcomeupdates\gamesbanner.png (dimensions 1280x288, took 36 msec)
00000248 45.59316254 [12624] DispatchAsyncEvent backlog, failed to dispatch all this frame. Queue depth: 941 (1530 input number was)
00000249 45.61946106 [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\welcomeupdates\friends.png (dimensions 768x512, took 36 msec)
00000250 45.63679504 [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\welcomeupdates\controllerbanner.png (dimensions 1280x512, took 35 msec)
00000251 45.63707352 [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\welcomeupdates\overlay.png (dimensions 768x512, took 36 msec)
00000252 45.68379211 [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\welcomeupdates\controller_update_overview.jpg (dimensions 1922x329, took 33 msec)
00000253 45.74924850 [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\welcomeupdates\controller_update_moystick.jpg (dimensions 1922x598, took 65 msec)
00000254 45.76589584 [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\welcomeupdates\controller_update_gyro_touchmenu.jpg (dimensions 1922x598, took 81 msec)
00000255 45.76611328 [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\welcomeupdates\controller_update_mouseregions.jpg (dimensions 1922x598, took 65 msec)
00000256 45.81578064 [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\welcomeupdates\controller_update_personalize.jpg (dimensions 1922x598, took 64 msec)
00000257 45.82481766 [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\welcomeupdates\controller_update_shortcuts.jpg (dimensions 1922x598, took 57 msec)
00000258 45.83283997 [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\welcomeupdates\controller_update_hometheater.jpg (dimensions 1922x598, took 65 msec)
00000259 45.84826279 [12624] HTTP Response for https://store.steampowered.com/api/featured/?cc=US&l=english: 200, 18472
00000260 45.91406631 [12624] Slow image load - https://steamcdn-a.akamaihd.net/steam/apps/219950/header.jpg (dimensions 460x215, took 23 msec)
00000261 45.91466522 [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\panel_header_background.png (dimensions 1920x128, took 23 msec)
00000262 45.91602325 [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\panel_background.png (dimensions 1920x1080, took 64 msec)
00000263 45.95051575 [12624] Slow image load - C:\Program Files (x86)\Steam\tenfoot\resource\images\background_alpha_mask.png (dimensions 1920x1080, took 33 msec)
00000264 45.98880386 [12624] HTTP Response for https://store.steampowered.com/api/featured/?cc=US&l=english: 200, 18472
00000265 45.99658585 [12624] OnFocusWindowChanged to window type: k_nGameIDControllerConfigs_Desktop, AppID 413080
00000266 45.99673462 [12624] Controller 0 Gamepad with Mouse and Gyro uses xinput : true
00000267 45.99827957 [12624] Loaded Config for Local Selection Path for App ID 413080: C:\Program Files (x86)\Steam\steamapps\workshop\content\241100\650764041/controller_configuration.vdf
00000268 45.99853897 [12624] Controller 0 Gamepad with Mouse and Gyro uses xinput : true
00000269 50.46805191 [8928]
00000270 50.46805191 [8928] === Begin DirectDraw / Direct3D leak report ========
00000271 50.46805191 [8928]
00000272 50.46813583 [8928]
00000273 50.46813583 [8928] === No leaked objects were found
00000274 50.46821594 [8928]
00000275 50.46821594 [8928] === End DirectDraw / Direct3D leak report ========
00000276 50.46821594 [8928]
00000277 50.57886124 [12624] >>> Adding process 12680 for game ID 33554432
00000278 50.70522690 [12624] OnFocusWindowChanged to window type: k_nGameIDControllerConfigs_Desktop, AppID 413080
00000279 50.70545959 [12624] Controller 0 Gamepad with Mouse and Gyro uses xinput : true
00000280 50.70761871 [12624] Loaded Config for Local Selection Path for App ID 413080: C:\Program Files (x86)\Steam\steamapps\workshop\content\241100\650764041/controller_configuration.vdf
00000281 50.70777512 [12624] Controller 0 Gamepad with Mouse and Gyro uses xinput : true
00000282 53.03483963 [12680] Direct3DCreate8 (SDKVersion = dc)
00000283 53.03525925 [12680] [dgVoodoo] INFO: Reading config from file C:\Users\wiseg\EphineaPSO\dgVoodoo.conf.
00000284 53.03554535 [12680] [dgVoodoo] INFO: INI file based version of config file is successfully read.
00000285 53.03735352 [12680] [dgVoodoo] INFO: D3D8 is successfully loaded: C:\Users\wiseg\EphineaPSO\d3d8.dll
00000286 53.03747177 [12680] [dgVoodoo] WARNING: Direct3DCreate8: Attempt to access Direct3D8 from DllMain. Application may need to be modified or patched to use with dgVoodoo.
00000287 53.03762054 [12680] [dgVoodoo] INFO: Reading config from file C:\Users\wiseg\EphineaPSO\dgVoodoo.conf.
00000288 53.03780365 [12680] [dgVoodoo] INFO: INI file based version of config file is successfully read.
00000289 53.07757568 [12680] [dgVoodoo] INFO: Direct3D8 (057DB570) DirectDraw has been loaded: C:\Users\wiseg\EphineaPSO\DDRAW.DLL
00000290 53.20409775 [12680] [dgVoodoo] INFO: Direct3D8 (057DB570) is created. Number of display outputs (on which devices can be created): 1
00000291 53.20417786 [12680] [dgVoodoo] INFO: Direct3D8 (057DB570) Device 0: Name: "AMD Radeon (TM) R9 M390X", Description: "\\.\DISPLAY1", Monitor rect: (0, 0, 3840, 2160), system primary monitor
00000292 53.20419693 [12680] [dgVoodoo] INFO: Direct3D8 (057DB570) Virtual video card is 'dgVoodoo Virtual 3D Accelerated' with 64MB onboard memory.
00000293 53.20435333 [12680] Driver :AMD Radeon (TM) R9 M390X
00000294 53.20442581 [12680]
00000295 53.20540619 [12680] Description:\\.\DISPLAY1
00000296 53.20548630 [12680]
00000297 53.20628738 [12680] VendorID :00000000
00000298 53.20636368 [12680]
00000299 53.20719528 [12680] DeviceID :00000000
00000300 53.20727921 [12680]
00000301 53.21051025 [12680] SubSysID :00000000
00000302 53.21053696 [12680]
00000303 53.21142197 [12680] Revision :00000000
00000304 53.21150589 [12680]
00000305 53.22371674 [12680] [dgVoodoo] ERROR: Direct3DDevice8 (058C4CF8)::Init/CreateAdditionalSwapChain: Out of videomemory, cannot create swapchain. Required bytes: 99532800, remained bytes: 61865984.
00000306 53.22373199 [12680] [dgVoodoo] ERROR: Direct3DDevice8 (058C4CF8)::Init: Cannot create device implicit swapchain.
00000307 53.22377777 [12680] [dgVoodoo] ERROR: Direct3D8 (057DB570)::CreateDevice: Initializing Direct3DDevice8 (058C4CF8) failed.
00000308 53.22407150 [12680] [dgVoodoo] ERROR: Direct3DDevice8 (0B152008)::Init/CreateAdditionalSwapChain: Out of videomemory, cannot create swapchain. Required bytes: 99532800, remained bytes: 61865984.
00000309 53.22409058 [12680] [dgVoodoo] ERROR: Direct3DDevice8 (0B152008)::Init: Cannot create device implicit swapchain.
00000310 53.22411728 [12680] [dgVoodoo] ERROR: Direct3D8 (057DB570)::CreateDevice: Initializing Direct3DDevice8 (0B152008) failed.
00000311 53.22451019 [12680] [dgVoodoo] ERROR: Direct3DDevice8 (0B152008)::Init/CreateAdditionalSwapChain: Out of videomemory, cannot create swapchain. Required bytes: 99532800, remained bytes: 61865984.
00000312 53.22454071 [12680] [dgVoodoo] ERROR: Direct3DDevice8 (0B152008)::Init: Cannot create device implicit swapchain.
00000313 53.22456741 [12680] [dgVoodoo] ERROR: Direct3D8 (057DB570)::CreateDevice: Initializing Direct3DDevice8 (0B152008) failed.
00000314 53.22494125 [12680] [dgVoodoo] ERROR: Direct3DDevice8 (0B152008)::Init/CreateAdditionalSwapChain: Out of videomemory, cannot create swapchain. Required bytes: 82944000, remained bytes: 61865984.
00000315 53.22496033 [12680] [dgVoodoo] ERROR: Direct3DDevice8 (0B152008)::Init: Cannot create device implicit swapchain.
00000316 53.22503662 [12680] [dgVoodoo] ERROR: Direct3D8 (057DB570)::CreateDevice: Initializing Direct3DDevice8 (0B152008) failed.
00000317 53.22525787 [12680] [dgVoodoo] ERROR: Direct3DDevice8 (0B152008)::Init/CreateAdditionalSwapChain: Out of videomemory, cannot create swapchain. Required bytes: 82944000, remained bytes: 61865984.
00000318 53.22528076 [12680] [dgVoodoo] ERROR: Direct3DDevice8 (0B152008)::Init: Cannot create device implicit swapchain.
00000319 53.22530746 [12680] [dgVoodoo] ERROR: Direct3D8 (057DB570)::CreateDevice: Initializing Direct3DDevice8 (0B152008) failed.
00000320 53.22551346 [12680] [dgVoodoo] ERROR: Direct3DDevice8 (0B152008)::Init/CreateAdditionalSwapChain: Out of videomemory, cannot create swapchain. Required bytes: 82944000, remained bytes: 61865984.
00000321 53.22553253 [12680] [dgVoodoo] ERROR: Direct3DDevice8 (0B152008)::Init: Cannot create device implicit swapchain.
00000322 53.22556305 [12680] [dgVoodoo] ERROR: Direct3D8 (057DB570)::CreateDevice: Initializing Direct3DDevice8 (0B152008) failed.
00000323 53.22560501 [12680] Fail Direct3DCreateDevice
00000324 53.22562408 [12680]
00000325 53.22826004 [12680] [dgVoodoo] WARNING: Direct3DCreate8: Attempt to access Direct3D8 from DllMain. Application may need to be modified or patched to use with dgVoodoo.
00000326 53.23189545 [12680] [dgVoodoo] INFO: Direct3D8 (05862A18) is created. Number of display outputs (on which devices can be created): 1
00000327 53.23191833 [12680] [dgVoodoo] INFO: Direct3D8 (05862A18) Device 0: Name: "AMD Radeon (TM) R9 M390X", Description: "\\.\DISPLAY1", Monitor rect: (0, 0, 3840, 2160), system primary monitor
00000328 53.23193741 [12680] [dgVoodoo] INFO: Direct3D8 (05862A18) Virtual video card is 'dgVoodoo Virtual 3D Accelerated' with 64MB onboard memory.
00000329 53.23223495 [12680] Driver :AMD Radeon (TM) R9 M390X
00000330 53.23226929 [12680]
00000331 53.23360062 [12680] Description:\\.\DISPLAY1
00000332 53.23361969 [12680]
00000333 53.23447800 [12680] VendorID :00000000
00000334 53.23450089 [12680]
00000335 53.23534012 [12680] DeviceID :00000000
00000336 53.23536301 [12680]
00000337 53.23620987 [12680] SubSysID :00000000
00000338 53.23622894 [12680]
00000339 53.23710251 [12680] Revision :00000000
00000340 53.23712158 [12680]
00000341 53.24308014 [12680]
00000342 53.24308014 [12680] === Begin DirectDraw / Direct3D leak report ========
00000343 53.24308014 [12680]
00000344 53.24322128 [12680]
00000345 53.24322128 [12680] === No leaked objects were found
00000346 53.24329758 [12680]
00000347 53.24329758 [12680] === End DirectDraw / Direct3D leak report ========
00000348 53.24329758 [12680]
00000349 53.24902725 [12624] OnFocusWindowChanged to window type: k_nGameIDControllerConfigs_Desktop, AppID 413080
00000350 53.24915314 [12624] Controller 0 Gamepad with Mouse and Gyro uses xinput : true
00000351 53.25102615 [12624] Loaded Config for Local Selection Path for App ID 413080: C:\Program Files (x86)\Steam\steamapps\workshop\content\241100\650764041/controller_configuration.vdf
00000352 53.25123596 [12624] Controller 0 Gamepad with Mouse and Gyro uses xinput : true
00000353 53.40605164 [12680] [dgVoodoo] WARNING: Leaked D3D8 objects detected at unloading D3D8 (probably process exit)!
00000354 53.61149979 [12624] OnFocusWindowChanged to window type: k_nGameIDControllerConfigs_Desktop, AppID 413080
00000355 53.61162186 [12624] Controller 0 Gamepad with Mouse and Gyro uses xinput : true
00000356 53.61346054 [12624] Loaded Config for Local Selection Path for App ID 413080: C:\Program Files (x86)\Steam\steamapps\workshop\content\241100\650764041/controller_configuration.vdf
00000357 53.61356735 [12624] Controller 0 Gamepad with Mouse and Gyro uses xinput : true
00000358 55.57763290 [12624] Game removed: AppID 0 "Ephinea PSOBB", ProcID 8928
00000359 55.70304108 [12624] **** Panel FavoritePages has fill-parent-flow for height, but isn't in a flowing down or up layout
00000360 63.26501083 [12624] OnFocusWindowChanged to window type: k_nGameIDControllerConfigs_Desktop, AppID 413080
00000361 63.26840210 [12624] Loaded Config for Local Selection Path for App ID 413080: C:\Program Files (x86)\Steam\steamapps\workshop\content\241100\650764041/controller_configuration.vdf
00000362 63.77277374 [12624] saving roaming config store to 'sharedconfig.vdf'
00000363 63.79288864 [12624] roaming config store 2 saved successfully
PSOBB error is provided here:
Failed : CreateDevice
Error : Can't use format [D3DFMT_X8R8G8B8]
Error : Can't find DisplayMode
Error : Can't use format [D3DFMT_A8R8G8B8]
Reply 15 of 33, by todd
The attachment dbgview3.log is no longer available
guys the only way I could get PSOBB to play with dgVoodoo 2 is changing the VRAM to 1024MB, in order to launch PSOBB at 4K resolution - which happens to be my monitors main resolution.
at this point you absolutely do not want to use dgVoodoo 2 even at 4K, because all game text, chat text, etc is converted to white and gold boxes with dgVoodoo 2.
here is a reason to run with classic fullscreen: if your computer experiences a speed issue, classic fullscreen runs 2-4 times faster than borderless window mode, or window mode. I heard this might be fixable by setting PSOBB to High priority but who knows, I prefer classic full screen mode anyway.
Reply 16 of 33, by todd
The attachment pso131786219660998651.jpg is no longer available
here's some screen shots of the windows 10 popup
Reply 17 of 33, by todd
By the way the above popup had to be taken with reshade directx8 to directx9 wrapper because dgVoodoo 2 wrapper cannot even display the popup before it crashes the computer.
Reply 18 of 33, by ZellSF
That was the popup I was talking about earlier. It's about the DPI setting, not the resolution setting, which again might correlate with a resolution change, but that's not what the popup is telling you about. It's also possible in the notification to tell it to not appear again, so why don't you try that if you believe that's the problem? I don't think it is, I think this is the problem:
Fairly sure Dege's position is that he doesn't support games that use DllMain. Maybe post about it here:
DllMain Thread
It's weird that it occasionally works though.
Reply 19 of 33, by todd
Hey I tested this on my grandpas desktop. That's a 1803 windows 10 system. It's a budget box with like 8GB RAM, Nvidia GeForce 730, 1080p display.
It does not display any sort of popup when running PSOBB at different resolutions and runs fine. Could be my grandpa disabled the popup already somehow as the kids play a lot of games on it.
But the text also is rendered fine on the nVidia box.
It does not render properly on my AMD 4K switchable graphics laptop at all. Wonder if this is AMD specific issue or what.
Otherwise game was ran identically. Launched from steam and all.
