First post, by aries-mu
Hi guys, excited to show you some data from a great guy who made a lot of tests on a 5x86 at various frequencies.
So, as expected, the advantages of a 40 MHz bus are well worth it!
You can see in some graphs as the 3D bench frame rates are higher for a 120 MHz CPU with bus at 40 MHz than a 133 MHz CPU with bus at 33 MHz!!! Although the CPU is 13 MHz faster, while the 120's bus is only 7 MHz faster, evidently the system is more "balanced", I don't know how to say, as the gap between FSB and CPU speed is more contained:
https://www.philscomputerlab.com/impact-of-ram-timings.html
non-truncated link:
Well, of course something beats the CPUs bussed at 40 MHz: the 50 MHz bus!!! 🤣
@Feipoa: You're gonna get raptured by those graphs! So many frequencies and, for each one and each test, tested different RAM wait states!
Comments appreciated.
Thanks.
They said therefore to him: Who are you?
Jesus said to them: The beginning, who also speak unto you
Computers should be fun inside not outside! 😉 (by Joakim)
