First post, by appiah4
I am putting together a 486 PC and that got me thinking when I was considering my sound options. I will probably go with a CT2290 for the build, but I'm not sure if I want to add a GM daughterboard or not. Since I will be using it for 1991-1993 games, I'm not even sure many if any games from the support GM at all? I know quite a few support MT-32, but I think GM is a rarity for the period? Even the SB16 was pretty expensive and rare when I got my DX33, but then my memories may be completely wrong 😀
Reply 1 of 17, by Shponglefan
I believe it was mostly 1993 and onward where General MIDI was more supported in games (esp. since the GM standard only came out in 1991). Games like X-Wing, Doom, MOO, Sam & Max, all released in 1993 and had GM support. Can't think of any off hand pre-1993 that had GM support...
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 2 of 17, by Jo22
I think the same. GM started approximately 1993. Before, there was MT-32 (and compatibles). And generic MIDI, as well.
Some Sierra games also supported popular Casio keyboards of their time (MT-540/CT-460/CSM-1/CT-660/..),
as well as the IBM Music Feature Card / Yamaha FB-01.
Anyway, there was no definite break, I think. It rather faded from MT-32 to GM.
Some games released 1993 onwards also still contained MT-32 support:
Princess Maker 2, Sam&Max, Lollypop, StarTrek 25th anniversary/Judgment Rites, MegaMan X, etc.
Edit: That beeing said, there's nothig wrong in adding a MIDI board to your PC.
If you're playing some games like Descent or like listening to MIDI music, a simple/cheap GM daughterboard is a nice addition.
Also, a few pre-1993 games had generic support for MIDI synths (Piano on channel 1 was common even on pre-GM).
Long story short: It's up to you. A DreamBlaster synth or one of the Terratec daughterboards can be found for little money.
Adding something valuable like a DB50XG might be a bit overkill for a slow machine, though.
On the other hand, that one is said to have some sort of an MT-32 emulation "mode" (MT-32 instrument mapping). Hmm. Tricky. 😐
Reply 3 of 17, by leileilol
Very yes. Waveblaster daughterboards (and supporting them) were a thing too
long live PCem
FUCK "AI"
Reply 4 of 17, by badmojo
More so than the Pentium era I'd have thought, because redbook was appearing late-486-era.
Reply 5 of 17, by Super_Relay
sort of depends on where you cut off the 486 era too. at least in my part of Australia Pentiums were still very expensive for a couple of years after release and it was still common for people to have 486s till the late 90s. Warcraft 2 has great midi support from 1995 and when I think back it was very much a game people played on their 486 DX2 66 or dx4 100
Reply 6 of 17, by badmojo
Yep "Pentium era" started to become a reality in about '97 or so in my world (also AUS).
Warcraft 2 also had redbook from memory? Classic MIDI in that game though you're right.
Reply 7 of 17, by appiah4
Well, by hardware era I almost always refer to the era when the hardware was the top dog, not the mainstream, so for me the 486 era is up to 1993/1994 and the Pentium era is up to 1997.. Regardless, if we put labels aside for a moment, would it be fair to say:
<1991: OPL2/3
1991-1993: MT-32
1994-1996: GM
>1997: Redbook?
Reply 8 of 17, by Super_Relay
yeah I remember it being on the CD, but you could definitely choose opl3 or midi. I remember the opl3 sound track the most because I used to play multi player with a friend direct modem to modem with a spawned multi install.
edit: That's probably a reasonable assumption but its not very cut and dried around the edges. wolf3d was a big release for 1992 and had no MT-32 but kings quest 4 had mt-32 support in I believe the late 80s
Reply 9 of 17, by Jo22
Yes, MT-32 support started by the late 80s. High-quality text adventures from Magnetic Scrolls or Legend Entertainment
featured the MT-32 as an alternative to AdLib (OPL2). They also supported SVGA in 800x600, by the way.
Reply 10 of 17, by appiah4
So I guess this is a better way to put it?
<1993: OPL2/3+MT-32
1993-1995: OPL3+GM
1996-1998:GM+Redbook
>1998: Redbook
Reply 11 of 17, by Super_Relay
That would be a pretty good way to sum it up i would think 😀
Catches most of the outliers i can think of, stuff like dune 1 where it supports both opl and mt-32 but the opl is better.
Reply 12 of 17, by leileilol
There's been plenty of redbook games from 1992 onward though...
long live PCem
FUCK "AI"
Reply 13 of 17, by Super_Relay
very true, but redbook support largely takes care of itself by the time you have sbpro compatibility or above and the cd drive you used to install the game from anyway so i never really figure it in to thinking about compatibility of a machine.
Reply 14 of 17, by Baoran
I think Pentium era started around 1995. I bought a 90Mhz pentium with win95 when win95 came out in 1995.
Reply 15 of 17, by firage
1995 is fair for new PC's. People with DX4's didn't really need an upgrade until '96, even DX2's were still mostly working for existing software.
My big-red-switch 486
Reply 16 of 17, by Jo22
In 1995, I had got a 286 with CD/16-Bit sound running DOS6.2/Win3.1.
In 1995, my father had got a 386DX40 w/ 16MiB running Win95 RTM.
And a 486 laptop w/ 4MiB, DOS6/Win3.11 and a monochrome LCD.
I haven't seen an actual Pentium PC until '98-99 (at the house of a schoolfellow ?).
Reply 17 of 17, by yawetaG
Jo22 wrote:
In 1995, I had got a 286 with CD/16-Bit sound running DOS6.2/Win3.1. In 1995, my father had got a 386DX40 w/ 16MiB running Win9 […]
Early Pentium systems often were very expensive compared to 486s in my country. IIRC, it was only during the MMX/P2 era that they really became commonplace...
