First post, by SSTV2
I cannot identify this card, it doesn't even look like a typical computer card, because it has very few pads on edge connector. It uses only 1 data, 10 address, AEN, clock and /IOW signals, it also supposed to have 2 DB9 connectors. ICs on card tell very little about its possible functions, it got 4x NEC 41264C dual ports graphics buffers (according to datasheet) a Toshiba TC17G series CMOS gate array chip (FPGA equivalent) and 32KB UV EPROM, which contains no ASCII simbols, just some random HEX values:
"DB DB 9B 9B 9B 9B 9B 9B 9B 9B 9B 9B 9B DB DB DB DB DB DB DB DB DB DB DB DB DB DB DB DB DB DB DB DB DB DB DB DB DB DB DB DB DB DB DB DB DB DB DB DB DB DB DB DB DB DB CA EA DA 9A 9A 9B FF FF FF DB DB 9B 9B 9B 9B 9B 9B 9B 9B 9B 9B 9B DB DB DB DB DB DB DB DB DB DB DB DB DB DB DB DB DB DB DB DB DB DB DB DB DB DB DB DB DB DB DB DB DB DB DB DB DB DB DB DB DB FB DA FA DA 9A 9A 9B FF FF FF"
hcxFhG2.jpg?1
Googled texts on card, but found nothing. What could it possibly be?
Reply 1 of 3, by stamasd
My best guess is it's some sort of industrial process controller. The NEC chips are essentially 64k x 4bit RAM arrays with both random and serial access and may be used to store process information or acquired data transmitted serially to/from an external device. Other than that I have no idea.
I/O, I/O,
It's off to disk I go,
With a bit and a byte
And a read and a write,
I/O, I/O
Reply 2 of 3, by SSTV2
Yes, it must be of industrial descent and it's definitely serial with only one data pin used on ISA bus. It probably uses RS422 or 485 protocols.
Forgot to add keywords: Gearbox DD 8602.5/1A, DatorDesign, Data Design, Dator Design, DD C701 TC17G022AT.
If anyone outside Vogons knows what this card does or where it comes from, please reply 😀
Reply 3 of 3, by cyclone3d
It looks like somebody cut off what I am guessing were DB9 connectors since it looks like both places on the edge of the board have the legs coming through the back of the board.
NM... I didn't see the first part of the post the first time.. 😵
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
