First post, by Saotome Ranma
Hi, there is a strange idea came out of my mind today, since I got a change to grab a really rare but interesting hardware recently.
A Matrox M3D, yes, the PowerVR 3D acceleration add-in card as everyone knows.
We all know that in the retro gaming era before the release of DX7, there were so many 3D accelerating APIs, such as Glide, SGL or Metal(S3TC). And different retro games feature difference APIs for the best image qualities and gaming experiences. So I wish to build up a retro gaming rig for as many available APIs (except D3D and OpenGL) as possible. Since both voodoo 1 and PCX2 are add-in cards, but only one primary video card can be used in dos/win9x, and S3TC and PowerVR features are only available under win9x, the main idea of my rig is like:
CPU: P3-533/667
(266/333@66 FSB, quite good for later 90s retro dos games and speed sensitive games, also powerful engine when it comes to win9x for my 3d graphic cards at its full speed)
MB: Asus CUV4X
(Via 694x chipset with ISA slot, ATA 100 support, nice dos compatibility IMO)
Video Cards Combination:
1.S3 Savage 4 8MB AGP (for its excellent dos compatibility and S3TC games, but S3D API available as Virge?)
2.Voodoo1 4MB PCI (for Glide games and dos games)
3.Matrox M3d (for SGL games)
But this is just an idea so i wish some experienced one could tell me whether such combination is possible or not? Any potential conflicts with those 3 video cards?
Besides, VIA chipset is notorious when it comes to AGP interface, like poor compatibilities with some AGP features, especially with TNT-series chips. But what about S3 Savage? Any buggy report for Savage on 694x? And what about the OpenGL compatibility on Savage 4? I have never used any Savage-series chips in Pentiums 2/3 era.
Please advise me if any experienced one with better idea!
Many thanks in advance!
The NOOB of noobs!!
Retro Games & Hardware サイコウ!
Reply 1 of 8, by canthearu
The biggest question I have is that was there actually anything really good done with S3TC worth futzing around with the savage 4 card for?
if you have other retro PCs to cover other bases, no problems, but if this is going to be your only retro PC, I'd probably steer you towards a geforce 2/geforce 4 mx card, along with the voodoo 1 and m3d cards to cover other bases.
I'd expect the possibility of more problems with the S3 card on a VIA chipset vs Nvidia or ATI cards, but that said, I've never really had any problems worth discussing with VIA AGP, as long as I install the correct drivers. I also am pretty sure the S3 Opengl drivers are pretty crap.
Reply 2 of 8, by derSammler
Yes, Unreal with high-res textures for example.
Reply 3 of 8, by matze79
hehe the Matrox m3d is a nice fit for older Thinkpads with PCI inside their Dockingstation 😁
Reply 4 of 8, by vlask
You have to choose between S3TC (Savage only) and S3D (ViRGE only). There's no mix between them. Rest of your cards looks like 1st gen, so i would go into ViRGE/GX or GX2 (or DX from diamond) for S3D games. You won't be able use higher resolution than 640x480, like with rest cards (voodoo limited to 640x480, matrox too due lower performance).
Savage give you S3TC, 800x600 resolution, in older titles maybe 1024x768 and OpenGL support. But OpenGL can be replaced by minigl drivers for voodoo 1 and im not sure about performance of underclocked Savage 4 with 8MB sold as cheap card for desktop use. Keep in mind, that savage 4 can also overheats, have stability issues in some games (mostly quake engine based) when using agp texturing and many games needs to be tweaked with s3tweak to run without freezing. So its not worth of troubles using it at 3D card....If you need 3D card from S3, go for faster Savage 2000 (still bugged drivers) combined with Voodoo 2 / SLI for glide compactibility.
Not only mine graphics cards collection at http://www.vgamuseum.info
Reply 5 of 8, by firage
I think you'll need to be downclocking that CPU to avoid Voodoo Graphics speed sensitivity issues. The V2 would be free of that problem, but they require quite a bit more tuning for many games.
My big-red-switch 486
Reply 6 of 8, by Saotome Ranma
Yes, that is the exact reason I'd like to try it. Not only the unreal, also some other games with S3TC texture patches like HL. But as it widely known, the S3TC supported games are quite limited, and the performance of Savage 4 8MB version is quite poor. So im still thinking of it... 🤣
The NOOB of noobs!!
Reply 7 of 8, by Saotome Ranma
So many helpful ideas, thanks buddy.
I know that Virge chip might be the better partner for the 1st-gen 3D add-in cards generally. But I got another MMX 133 retro rig with integrated 2MB Virge onboard, I think that is enough for the normal 486/pentium level retro dos games or even S3D games. So this rig is mainly aimed for those later 90s high performance demanding dos games and early win9x games with rare APIs support at its max 3D speed, with no CPU bottleneck hits and faster HDD transfer speed. Besides, the Virge's 2D speed is quite slow with poor color and resolution support in win9x. I wish to connect the primary graphic card to an LCD in 1280x960, which is perfectly suitable for upscaled 640x480/400 dos and windows games. And the image quality of Virge is quite unstable, something very depends on the Manufacturers. This is the main reason Im thinking of using a low specs Savage 4, fully DX 5.0 support, much faster 2D speed, much better color and high resolution support in win9x desktop, with still excellent dos games compatibility.
I may build up another rig with a 800Mhz ~ 1Ghz Pentium 3, a PCI voodoo3 3000 and an AGP Savage 2000 or Matrox G400 (G400 preferred since it got better image quality with decent OpenGL compatibility according to Phil's video reviews, btw Savage 2000 is very hard to be found in Japan...) for those DX5~6/voodoo2 era/early OpenGL games. IMHO, Voodoo 3 3000/3500 is a perfect replacement for Voodoo2 Sli, with stronger performance and much better image quality but only one interface slot occupied.
Another question: will a Pentium3 533/667 become the bottleneck for Savage 2000 or high specs Savage 4 (like 32MB version)? if not, I may find one for the rig.
The NOOB of noobs!!
Reply 8 of 8, by Saotome Ranma
Yes, the CPU clock could be lower into 266/333Mhz when FSB set in 66Mhz, that is equal to MMX or PRO 233~350Mhz IMO, very decent for high performance demanding 3D dos games and early win9x speed sensitive games. Other dos games will be handled in another rig or DOSBOX.
The NOOB of noobs!!
