dr_st wrote:In other words, disable everything that makes SSD useful? Pagefile on HDD? Come on. It doesn't get any more pointless than that.
The only thing that really and definitely makes sense to disable is defragmentation (SSD-aware OSes should do it automatically, but 9x/XP are not). Indexing and prefetch - you either want them or you don't, in which case it makes sense to disable them whether you use SSD or HDD. Same for hibernation.
Indexing and prefetch services was meant for HDD to dimnish access/seek/loading time problems (for typical consumer tier HDD drives). This is not a problem for SSD, causes unneccessary I/O operations and may be disabled. Whether somebody likes or not, pagefile is being used constantly. Eg. my system with 5Gb RAM running XP (+Linux on another hdd), has 270 MB paging use after boot up on idle. AFAIK XP defaults to half of the RAM for paging space, and aside some permanently occupied space, pages are constantly being pushed in and out by the system. It means more pressure on SSD wear leveling (when no TRIM is available) and to remedy this, pagefile usually goes on hdd - you won't notice a speed decrease anyway (did you while using HDD only? - only if RAM was full). Besides, I did not invent those tricks, they were born by experience of many people in times when SSD were sucky, small, expensive and people still used OS older than Win7 wihout TRIM. Even Linux has TRIM support from circa 2010 (kernel 2.6.30 something). So not that pointless. I even disable some services to increase available RAM. But you may enable all of them - it is your PC.
stamasd wrote:SLC really? I can't afford SLC drives on my main computer. 🙁
I can recommend two approaches:
1) buy some recent MLC drive, samsung, crucial or other reputable brand 120GB if for system + data on HDD or 250+ for system+data
2) budget solution: msata SSD + msata to sata adapter from ebay + HDD for data. You can score cheaply on ebay drives from old netbooks varied 8-32 or even 64gb used, sometimes even SLC if you're lucky (those from first netbooks), employ few tricks to make yours SSD drive life longer and your're ready to go. Even some old drives do not have TRIM at all, just the Garbage Collector, so don't worry if you don't chew few hundreds of terabytes of data on your retro system. I myself have one XP system on Toshiba SSD 8GB which is MLC, has single flash chip, is slow 9for SSD), but still running fine. Your choice and money.
From experience I used Samsung SSD 840pro on sata1 (150) and I felt full speed of it only on sata3 interface. Using SSD on slow interface won't be a superb experience, but still noticeably faster than HDD, even when considering access time only. Keep that in mind though. My 2 cents.
