First post, by tabm0de
- Member
Sorry for the st*pid question. but does all creative cards support gameport to midi?
naa, nothing yet...
naa, nothing yet...
Starting with the SB16. Live!/Audigy DOS drivers don't.
Technically, Sound Blaster cards prior to the SB16 do support MIDI over the Gameport in "SB-MIDI" mode. This would allow for connections to/from keyboards, etc, but not usually in games (I'm not personally aware of any). To be clear, this is neither MPU-401 Intelligent nor MPU-401 UART compatible.
This issue can be mitigated somewhat with Soft-MPU, but has limitations.
MT-32 Old, CM-32L, CM-500, SC-55mkII, SC-88Pro, SC-D70, FB-01, MU2000EX
K6-III+/450/GA-5AX/G400 Max/Voodoo2 SLI/CT1750/MPU-401AT/Audigy 2ZS
486 Build
Ok, thanks for the answers 😀 ( both of you of course 😀 )
naa, nothing yet...
