First post, by GabrielKnight123
Hi all, I have a (Luckystar?) 5i-vx1e motherboard and I have a Pentium w/ MMX BP80503200 SL25N cpu but in the manual:
http://www.elhvb.com/mboards/luckystar/manual … 1E/5ivx1ejp.pdf
http://www.cpu-world.com/sspec/SL/SL25N.html
there are two settings for the Pentium on page two ie P54C 200 and P55C 200 the only difference is the JP8/JP9/JP10 and JP15, which one should I use for the SL25N CPU as the core voltage is 2.8V and the I/O voltage is 3.3volts.
