First post, by GabrielKnight123
Hi all, I have a 200W AT power supply and the fan needs replacing so I would like to do a test with a multi meter before I use it, its a switching power supply and I read that I should not test it without it having a load so how do I do this if needed and do I just compare the pinout of the 12 pin power connector with how they are?
ie:
http://pinouts.ru/Power/MotherboardPower_pinout.shtml
Reply 1 of 11, by root42
Maybe attach a 12V halogen incandescant light bulb to it? That should qualify as a load... 😀
YouTube and Bonus
Reply 2 of 11, by gdjacobs
For a one shot test, you can take a pail of water with your leads inside and calibrate it by using any electrolyte (salt, H2SO4, etc). You're going to want about one ohm of impedance (no need to run at full blast).
https://en.wikipedia.org/wiki/Liquid_rheostat
Reply 3 of 11, by Errius
I remember reading somewhere about dedicated PSU testing machines. Does anyone know about these?
"AI Requires Proof That You Are Human"
Reply 4 of 11, by Koltoroc
they are stupidly expensive
Reply 6 of 11, by 133MHz
I use a combination of 4R7 7W ceramic resistors (each one draws roughly 1A @ 5V) and 50W 12V halogen lamps for load testing computer power supplies.
http://133FSB.wordpress.com
Reply 7 of 11, by konc
I just connect a failed-but-still-spinning hard disk
Reply 8 of 11, by GabrielKnight123
Ok so if I connect three good working hard drives, the power supply has 3 molex and 2 floppy, and nothing to the main 12 pin plug would that be enough for a load test? Also the fan does not work so how long could I play around with it without a fan sucking hot air out or can I take the cover off and hope it doesnt get hot?
Reply 9 of 11, by gdjacobs
Three working hard drives should only be good for <<100 watts. Also, if the fan is seized it should be pulled. You can temp in another fan, either external or internal, to guarantee airflow into the PSU.
Reply 10 of 11, by GabrielKnight123
If 3 hard drives only use about 100 watts how much wattage do I need to use before the 200 watt power supply is in a load state?
